65 Coupe Bulkhead connector - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 952
    While diconnecting the bulkead connectors at the firewall, I broke the upper plastic lock tab that holds the plug together. Is there a way to lock the plugs together without the plastic tab?
    Dave K.
  • Frank D.
    • December 27, 2007
    • 2703
    Re: 65 Coupe Bulkhead connector
    Dave K.
    I went through the same thing on my 63, those metal terminals are friction contacts and nothing I tried secured the housings tightly enough...not zip ties or tape or trying "Plastic Weld" to reattach the locking tab. If something did work I would be skeptical about how long it would do so.
    I wound up buying a repair kit from Lectric Limited ($125) and "re-pinning" the bulkhead metal connectors into the new plastic housing - not for the faint of heart but I had a lot of experience with Canon plugs from my avionics days. I didn't use the new pins, but the kit was the only way LL would sell the housings... The job requires the round tool shown to get the pins loose safely.
    • Frank D.
      • December 27, 2007
      • 2703
      I put a PDF document together complete with pictures, part numbers and tips during a bout of insomnia this morning that you may refer to if you want to tackle installing new plastic bulkhead connector housings.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11322
        Frank, Nicely Done!
        I will add that to the Database when I can.
        Riich
        • Dave K.
          • November 1, 1999
          • 952
          Thanks to all.
          Dave K.
          Chairman Pgh Tri-state Chapter NCRS
          • Frank D.
            • December 27, 2007
            • 2703
            Friend and PDF wizard Dave Zuberer did some quality revisions to my blurb on this issue; folks should grab this version if they're interested.
