1969 Alarm Switch Backing Plate - NCRS Discussion Boards
  • Floyd B.
    • November 1, 2002
    • 1053
    The UA6 alarm system was neutered by a previous owner but the horn, wiring, hood switch and relay/flasher bracket are all still in place. The rear taillight panel was replaced circa 1978 and the alarm switch was not replaced. Sourcing a new wiring harness and other missing parts is not proving to be problematic - except for the backing plate that supports the key switch. It appears on UPC UA6 - A4 in the AIM. Part # 3937672.
    It appears to be nothing more than a steel plate about 3"x5" with a 13/16" hole drilled in the center. However, I have been unable to find a picture or example of this plate. Any information or pictures you have would be appreciated.
    Thanx
    "Drive it like you stole it"
    • 43290
    Re: 1969 Alarm Switch Backing Plate
    Thanx
    Floyd------
    I think the plate was pretty much as you described. It was once available in SERVICE but was discontinued without supersession in May, 1979.
    • Floyd B.
      • November 1, 2002
      • 1053
      Thanx Joe. I'm hoping someone with a '69 and RPO UA6 will be willing to help me out. I could really use a picture from the backside that shows the backing plate and a picture of the switch from behind the car that clearly shows the location of the switch. The AIM indicates that a 13/16" hole is to be drilled centered on the rear valance and 5.90" up from the top of the license plate cutout. But I would really like to get some pictures before I start drilling a hole in my car.
        • 43290
        Floyd------
        It will have to be someone else besides me. Why? When I ordered my 1969 new I did not order the alarm system? Why? Primarily because I did not want the switch installed on the rear panel.
        • Floyd B.
          • November 1, 2002
          • 1053
          Yeah - I'm not crazy about the idea, but it's obvious the car originally had UA6 installed. Besides, back in '69, that option would have set you back $26.35! That would about $186.62 in 2020.
