C2 Headlamp Bezel Width - NCRS Discussion Boards
  • Larry E.
    • November 30, 1989
    • 1662
    While we are on this subject I noticed that on my 66 Coupe the Headlamp Bezel Width is a little bit different from
    each other. The P/S one is 1/8" (,125) less then the one on the D/S one. Of course the final outcome is that
    the inner gap is bigger on the P/S 1/4"(.250) compared to the gaps on the D/S. Specs call for up to .18 gap. I got
    to believe my bezels are original to the car. Has anybody noticed this difference on their C2's?? Thanks in advance
    Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Leif A.
    • August 31, 1997
    • 3611
    Re: C2 Headlamp Bezel Width
    Larry,
    Are you saying that your actual headlamp bezels are a different width OR the headlamp bezel opening is different side to side?
    Leif
    • Larry E.
      • November 30, 1989
      • 1662
      Originally posted by Leif Anderson (29632)
      Larry,
      Leif>Headlamp bezel openings are the same; but the bezels themselves are different. Not much but different. Yours?? Larry
      Larry
      • Leif A.
        • August 31, 1997
        • 3611
        Larry,
        I've never measured them but I will when I get home.
        P.S. OK, I'm home. Right side bezel is 13 7/8" measured across the top of the bezel where it meets the bucket. Left side bezel is 13 15/16". Most likely attributable to body work/paint work over the last 53 years.
        Leif
        • Larry E.
          • November 30, 1989
          • 1662
          Larry,
          Leif: I assume your Bezel Openings are the same; so that being said are you gaps slightly smaller on your Left Side compared to
          your Right Side?? Larry
          Larry
          • Larry E.
            • November 30, 1989
            • 1662
            Thought I would bring this up once more. Upon closer inspection I found that the P/S Bezel is slightly smaller then the D/S and that
            the Bucket Width Openings are a "hair" wider on the P/S than the D/S. When you add all this up you have the gaps that are wider
            on the P/S and D/S. We are talking small amounts but it is noticeable. Talking to previous owners and doing some inspection there
            is no sign the car was ever in an accident. The gaps on both sides closer to the windshield have the small radius curve like they
            supposed to. Question>Since we are talking about a 54 year car is it possible the the dimensions have change ever so small? Has
            anybody else notice this. We have to assume that when it left St.Louis the gaps where in tolerance. Comments Please>Larry
            Larry
            • Frank D.
              • December 26, 2007
              • 2703
              I'm not sure how the surround headlight bucket gaps would grow or shrink from the original, factory dimensions - others may know differently.
              • Larry E.
                • November 30, 1989
                • 1662
                Thanks Frank for the comments. That being said lets just assume there never bodywork done to the car. IS IS POSSIBLE/PROBABLE THE
                DIMENSIONS HAVE CHANGED IN THE 54 YEARS?? EVER SO SLIGHTLY??? Larry P.S. I know my car like many others when new was
                used as an everyday day in ILLINOIS. That means the temperature variance was from 105 degrees to -15 degrees every year.
                Larry
