1963 coupe body mount cushions - NCRS Discussion Boards
  • Frank D.
    • December 27, 2007
    • 2703
    #31
    Re: 1963 coupe body mount cushions
    Originally posted by Harry Sadlock (38513)
    Oops.....
    Uh yeah - I was looking specifically for the inner mounts but I think we can presume those were also taped.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11345
      #32
      Originally posted by John Ftacek (48800)
      Thank you everyone for the pictures and info. Blue painters tape will high light my nassau blue paint.
      Not blue, but BLACK might be appropriate.....
      Rich Y's very original 63 convertible when it was here on my lift. Very interesting tape I've never seen before. It's a "2-ply" black over tan which separated over the years.
      Rich
      • Frank D.
        • December 27, 2007
        • 2703
        #33
        I know that car; if you see something on there, its most prob original...
        I've used it to confirm several points of originality on my own 63.
        The wheels and IIRC convertible top were replaced...it has the original lacquer paint which has held up quite well.
        Not sure how you would replicate that tape on rubber cushions and still be able to get the piece in the cavity with the body on the car...
        It wasn't worth it to me to try...
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11345
          #34
          Might be able to use some rubber cement and just tape sharply cut pieces to the edges of the cushions on both sides.
          • Harry S.
            • July 31, 2002
            • 5333
            #35
            Frank, do you recall what the headmark on the bolt was?
            • Frank D.
              • December 27, 2007
              • 2703
              #36
              I do not and am away from my car for the holiday so no quick way to check..
              • Harry S.
                • July 31, 2002
                • 5333
                #37
                Happy Holidays
                • Wayne G.
                  • April 30, 1984
                  • 143
                  #38
                  • Wayne G.
                    • April 30, 1984
                    • 143
                    #39
                    • Harry S.
                      • July 31, 2002
                      • 5333
                      #40
                      Wayne, The body on my 63 coupe has never been off the frame. As I understand the WB is a good headmark. Your bumper bolts are fine.
                      Harry
                      • Wayne G.
                        • April 30, 1984
                        • 143
                        #41
                        • Timothy B.
                          • April 30, 1983
                          • 5198
                          #42
                          Wayne, Can you tell me the length of those bolts from the center rubber cushions (under head to extreme pointed tip). Thanks, Tim
                          • Harry S.
                            • July 31, 2002
                            • 5333
                            #43
                            Tim, This is the bolt in the kit from CC, clearly incorrect.
                            • Wayne G.
                              • April 30, 1984
                              • 143
                              #44
                              Tim,
                              From under the head to the tip is 2 3/8". I will take some pictures for you.
                              Wayne
                              • Wayne G.
                                • April 30, 1984
                                • 143
                                #45
                                Tim,
                                Pictures of the center cushion bolt. Bolt and lock washer is cad/zinc. The flat washers are black Phosphate.
                                Wayne
