1963 coupe body mount cushions - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2417
    Re: 1963 coupe body mount cushions
    Frankie, did you video by chance?
    • David L.
      • July 31, 1980
      • 3310
      My 1963 Chevrolet Parts Catalog (Oct. 1962) does not list any body mount cushions for the 63 Corvette in Gr. 9.023.
      My 1964 Chevrolet Parts Catalog (Oct. 1963) lists following for the 64 Corvette & 64 Corvette (Spt. Cpe.)
      with the following description: CUSHION , No. 3, 4, No. 1 (1 5/8 O.D. x 1/2 thk.).........3842914 A.R.
      and CUSHION ASSY., No. 3, 4, No. 1 (w/spacer)........................................... ..............3842913 A.R.
      These same part numbers are listed in my 1967 Chevrolet Parts Catalog in Gr. 9.023 for 64-67 Corvettes.
      Dave
      • Alan D.
        • January 1, 2005
        • 2050
        #18
        Here is what I used, thickness is 1/2" These are for a late model 64, not specifically for the seat belt area.
        Had no problem installing, finished product was a little fatter than original
        • Alan D.
          • January 1, 2005
          • 2050
          #19
          See post #16 for tape comment.
          My undersstanding is that all the rubber mounts with shim(s) got tapped before being installed
          That has been confirmed by looking at my Mar64 car. Note, it's never had body removed and I've
          owned since Aug67, know original owner also (NCRS member)
          Tape in photo is on right side hanging down and top of cushion where you see the white.
          • Frank D.
            • December 27, 2007
            • 2703
            #20
            Originally posted by John Ftacek (48800)
            What does this mean? I have never done it or scene it before.
            Original cushions, at least the inner 63 cushions, had a yellowish appearing (perhaps from age) tape around them going over the top and down the sides; I don't know if it wrapped completely around the cushion. It may have to hold the large flat washer to the bottom of the cushion during installation presumably.
            My car did not have shims at either inner mount cushion location and I did not add any. This is the top of my original cushion with the tape remnants,
            No I did not video the cushion installation, there was nothing really special about it except using a short crowbar between the rear of the frame mount and the metal bracket riveted to the body to get enough space to insert the cushion into the well-lubed factory cavity...
            Then using a screwdriver to align the frame mounted captured nut, the large flat washer, and the cushion with the hole in the body for the bolt...then just insert and snug the bolt down..
            • Michael M.
              • February 1, 1993
              • 604
              #21
              Frank, can you measure the diameter of your cushion? I want to know for reference on the cushions (GM #3842914) I have.
              • Harry S.
                • July 31, 2002
                • 5333
                #22
                I'm interested also, the 3842914 OD is about 1 5/8.
                I'll take a guess and say it's about 2 1/2.
                • Alan D.
                  • January 1, 2005
                  • 2050
                  #23
                  Here is the one I removed, it's diameter is 2 1/6", remember it's been squeezed for over 50 years, so would assume the 2" is correct.
                  The cushion under discussion has been the 3832539 used in two spots in 63 - most of 64. When the new frame support was added (around April 1964) that area used the same 3832539. So the kit from LI has all 4 as the same, ie 2" X 1/2"
                  So why are we concerned with the 3842914??? PS it's 1 5/8" see photo
                  A few more pictures;
                  • Harry S.
                    • July 31, 2002
                    • 5333
                    #24
                    Alan, just walked under the 63. My squashed one is 2.5, so 2.0 is good.
                    • Frank D.
                      • December 27, 2007
                      • 2703
                      #25
                      Measured installed cushion with dividers then compared that to ruler and came up with 2-3/8"; now remember - that's distended due to being bolted down.
                      Original vs repro; now I have not cranked down on the repro via the bolt very hard, once it felt like the bolt was getting tight and the surfaces mated solidly I left things at that, there is also some "slop" in how you position the cushion as the bolt hole diameter in the rubber is larger than the bolt diameter by a good factor. I'm actually pretty satisfied with the look, fit and composition of the repro cushions from Corvette Central.
                      • John F.
                        • March 23, 2008
                        • 2417
                        #26
                        Thank you everyone for the pictures and info. Blue painters tape will high light my nassau blue paint.
                        • Michael M.
                          • February 1, 1993
                          • 604
                          #27
                          John, I do not believe the factory used blue painters tape.
                          • Harry S.
                            • July 31, 2002
                            • 5333
                            #28
                            Richard Drew, a 3M scientist, invented masking tape in 1925. It was originally developed for use in two-toned painting on automobiles. The product now known as ScotchBlue™ Painter's Tape was invented by 3M in 1988. It was designed for professional painters to use in residential and commercial painting applications.
                            • Frank D.
                              • December 27, 2007
                              • 2703
                              #29
                              I think it was thick clear tape and what we see today is discolored, aged remnants; I went through several videos of the St. Louis assembly plant build process and some John Hinckley presentations and couldn't find a good picture of the body mounts with tape on them, but they were clearly used..
                              • Harry S.
                                • July 31, 2002
                                • 5333
                                #30
                                Oops.....
