'72 T-strap for vacuum lines - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    I see 5 straps called out in the aim so two questions. Are they supposed to be 5" or 7" ? And I correct that there are only 5? Thanks!
  • Edward J.
    • September 15, 2008
    • 6942
    Re: '72 T-strap for vacuum lines
    Tom, does your t straps at the brake booster have a cut To make shorter 72 the neatened up all the vacuum hoses and was wondering if this was normal. Sorry my car is on the lift, I will look for you. Maybe later. I am about to head out for afternoon.
    • Tom L.
      • October 17, 2006
      • 1439
      I had nothing and bought 4-7" straps and put them on, they seemed long to me. I have a NOS 5" strap and it seems better suited for the task, the 7" strap seems real long at the booster. At the headlight actuators they're kind of hidden from view. The vendors list both as being used for 68-82 vettes so I'm unsure.
      • Leonard M.
        • September 7, 2009
        • 236
        Tom, These are original. I did not measure them, but you should be able to figure it out from the length of the tail.
        • Edward J.
          • 6942
          Tom my 72 has 4 long and 1 short the short one Is under the front middle.
          • Jack C.
            • September 30, 1992
            • 1090
            72 Original straps.
            Jack Corso
            1972 Elkhart Green LT-1 Coupe 43,200 miles
            Top Flight 1994, 2018 & 2021
            • Tom L.
              • October 17, 2006
              • 1439
              Was just googling around the part number called out in the AIM, 4778650. Comes up as a variety of GM parts but one vendor did note that this particular strap is in fact 7" long as shown in Jacks and Leonards pics. My only question would be about Edwards comment about the "1 short the short one Is under the front middle". (Corvette comments only ) I'm Ok with that especially since I have 4- 7" straps and 1- 5" on hand. The AIM calls out the 7448650 strap for all 5.
