Another 72 LT1 renovation question - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4607
    Re: Another 72 LT1 renovation question
    Originally posted by John Sigmund (61302)
    Fred, I also recommend the system from Corvette Central if you’re going to replace yours. I installed the complete 2 1/2” aluminized system on my L82 and I was very happy with the fit, function and sound. The system judged well, standard deduction for aluminized system, but I think that was the only deduction I received. Also worth the wait for the free shipping offer if it’s still available. Good luck.
    No Configuration deductions for the mufflers or pipe bends?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
      • 11692
      Depends how you want to argue that one.
      If you read the standard deduction section, it mentions the 25% for aluminized. There is no comment stating 25% plus CDCIF.
      I'm not saying it doesn't happen, but most will deduct 25% alone; there are those who do 25% plus.
      • Mark E.
        • April 1, 1993
        • 4607
        #18
        Good question. Does the standard deduction cover all CDCIF? Or only Finish?
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Dick W.
          • 10483
          #19
          I believe that you will find your answer below
          C: Configuration
          D: Date Code
          C: Completeness
          I: Installation
          F: Finish
          Dick Whittington
          • Leonard M.
            • September 7, 2009
            • 236
            #20
            Here's some pictures from my '70 LT-1's exhaust system. It is the Corvette Central aluminized system with welded mufflers that Patrick mentioned.
            • Fred H.
              • December 4, 2019
              • 317
              #21
              Good morning Leonard, the photos you provided are very helpful, and much appreciated. Fred
              Fred Hickey
              Care taker of Top Flight 72 LT1 C60 Convertible #26756
              • Dick W.
                • 10483
                #22
                [ATTACH=CONFIG]100186[/ATTACH][ATTACH=CONFIG]100187[/ATTACH][ATTACH=CONFIG]100188[/ATTACH][ATTACH=CONFIG]100189[/ATTACH][ATTACH=CONFIG]100190[/ATTACH]
                I believe it would take a deduction for the pipe bend configuration and of course the mufflers.
                Dick Whittington
                  • 11692
                  #23
                  Again, depends on how you want to read the rules.
                  If the JRM stated that it was 25% plus appropriate CDCIF deductions, that would be easy. But, it doesn't. It only states that aluminized systems receive a 25% standard deduction.
                  Since the other standard deductions (battery, tires, glass) are not a percentage plus, most of us do not treat exhaust any differently.
                  PH
                  • Dick W.
                    • 10483
                    #24
                    PH
                    OEM pipes are mandrel bent without the indentation for the shoe of the pipe bender. A deduction in my book.
                    Dick Whittington
                      • 11692
                      #25
                      I'm well aware they are different. I'm just citing the rule and the logic of current judging for exhaust.
                      • Mark E.
                        • April 1, 1993
                        • 4607
                        #26
                        PH
                        Thanks Patrick. This is what I was (trying) to ask.
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                        • Mark E.
                          • April 1, 1993
                          • 4607
                          #27
                          I thought CC exhausts have mandrel bends. I guess they don't.
                          Mark Edmondson
                          Dallas, Texas
                          Texas Chapter
                          • Dick W.
                            • 10483
                            #28
                            In my mind the bends deserve a deduction under Configuration, not a full, but partial
                            Dick Whittington
                            • Gary J.
                              • April 1, 1980
                              • 1246
                              #29
                              • Mark E.
                                • April 1, 1993
                                • 4607
                                #30
                                Originally posted by Gary Jaynes (3503)
                                Doesn’t the Gardner pipes have the mandrel bends? Just asking the question? If they do would you not be better off getting the carbon steel than the aluminum ones for a less point deductions?
                                Why would mandrel bends earn fewer deductions than compression bends when neither are original?
                                Mark Edmondson
                                Dallas, Texas
                                Texas Chapter
