turn signal issue - NCRS Discussion Boards
turn signal issue
  • Bruce W.
    • June 30, 1997
    • 360
    turn signal issue
    Hey guys, Having trouble with the turn signal.right side Only works if I hold the turn signal up. left turn works fine. Won't flash if I don't. does sound like an adjustment or do i need a new part?
    Bruce
    • 6956
    Re: turn signal issue
    Bruce,sounds like switch in column is acting up. They do make a repair kit for switch if needed.
    • Bruce W.
      • June 30, 1997
      • 360
      Ed, already have a new switch installed? Do you think it could be the cancelling cam?
      Bruce
        • 6956
        Bruce the cancel cam only returns arm to neutral position,is it a repro. Switch? Also check the connector under dash the pins have been known to slide out. Was the switch working normally when you installed?
