restored 69 tach and speedo not working - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1416
    Guys,
    In my 69 4spd L 46 I'm restoring I had my tach and speedo restored. I've connected them correctly as far as I can tell by looking at the AIM. The connection to the trans and distributor I thought was pretty straightforward, and as far as I can tell they just "plug into" the back of their respective gauges. Nevertheless, neither is working at all. What could I be missing? I'm guessing the next step is to disconnect them from their gauges with the car running and see if the cable is spinning?
    Mike
  • Bob I.
    • November 9, 2006
    • 265
    Re: restored 69 tach and speedo not working
    I would check that the cables are locked in at back of the tach and speedo.
    Bob
    • Michael L.
      • December 15, 2006
      • 1416
      They are both securely clipped in to the back and appear to be flush with the housing.
      • Philip A.
        • September 18, 2021
        • 94
        what was the issue with your speedo and tach? I assume you got it figured out.
