C1 window regulator repair - NCRS Discussion Boards
  • Ed P.
    • July 31, 2002
    • 270
    Need to replace gear plate on 60 window regulator. Remove spring and rivet. Spring holder stud is crimped over so is correct procedure to grind off then weld stud back to plate.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17769
    Re: C1 window regulator repair
    Ed,
    Attached is a PDF of the article I wrote for the Texas Chapter Talepipe Newletter with the steps I used many moons ago to replace a '57 window regulator gear.
    IIRC I got the how to tips from Joe Calcagno of the Southern California Chapter.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Terry D.
      • May 31, 1987
      • 2696
      If you would rather not do this yourself, Paul Mazt is your guy. 413=243-3439
      • Ed P.
        • July 31, 2002
        • 270
        Thanks for info
        • Gary B.
          • February 1, 1997
          • 7046
          Originally posted by Gary Chesnut (5895)
          Ed,
          Gary
          Gary,
          Joe is also a member of the Northern Cal Chapter and his shop is in Soquel, which in a bit southeast of Santa Cruz, so in the northern part of the state, relatively speaking. His website is rarecorvettes.com.
          Gary
