1969 How to get hood open - NCRS Discussion Boards
  • Mark G.
    • January 31, 2007
    • 177
    Re: 1969 How to get hood open
    I have a copy of bulletin 71-I-11 mentioned earlier. The file is too large to post here. I can send a copy to whomever wants one. I don't have my 70-2 TIGJM on hand, but I thought it was in it.
    • Mark E.
      • April 1, 1993
      • 4537
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Mark G.
        • January 31, 2007
        • 177
        Here is the bulletin. The tool is pictured full size. In case it does not print out correctly, the dimensions are shown.
        • David M.
          • September 30, 2004
          • 522
          Mark, Jeff, Terry, Richard Thanks!
          Its going on the lift today. Ill be sure to close the loop here for the benefit of all early C3'ers with the same problem.
          This will make an excellent technical archive to help everyone in the same conundrum.
          TX
          Dave
          • Mark E.
            • April 1, 1993
            • 4537
            Is this tool really needed along with punching out the rubber plug?
            I've never done this, but several YT videos suggest an easier way is to remove the fender splash shield and reach up from below. And for 70-72, either side can be reached by removing the fender grill. This may be trickier for big block or AC cars (right side).
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • David M.
              • 522
              Id say its good to be armed with as many tools as possible before surgery.
              • David M.
                • 522
                We got it open in 2 minutes while it was on the lift.
                The cable wasn't installed correctly at the driver side latch and had pulled out.
                Ill close the loop here after I get the full story from the mechanic.
                Ill compile all the info from this thread in one spot for the next guy. Maybe it can be made into a sticky for 68-69 cars.
                TX
                Dave
                  • 15599
                  TX
                  Dave
                  Congratulations
