L63-64 Water Pump - NCRS Discussion Boards
L63-64 Water Pump
  • Joe R.
    • July 31, 1976
    • 4551
    Re: L63-64 Water Pump
    There are two reasons!
    1. The statement that "I know my 63 is original because I bought it from the original owner"!
    Answer: It's only 57 years old and all original water pumps last that long!
    2. The 63-64 Judging Manual is incorrect and nobody wants to fix it again!
    Answer: It's not incorrect cause it has been changed about ten times!
    JR
    • Alan D.
      • January 1, 2005
      • 2046
      Joe has a point, when I purchased my 64 (in 1967) it had under 30K miles on it and water pump had been replaced already.
        • 43247
        #18
        Alan-----
        As I've said many times before, the 5/8" shaft waterpumps used for all 1955-70 small blocks are not particularly long-lived pieces. If one gets 50,000 miles of service, one has done very well. Many fail well before 50,000 miles.
        For 1971 and later GM went to 3/4" shaft waterpumps for small blocks (big blocks were always 3/4"). They did not do this because the 5/8" shaft pumps were just as good.
        When I say shaft size I am referring to the size through the bearing. The impeller end of the shafts for both small and big blocks was always reduced to 5/8".
