I should have taken more pictures when I pulled this thing apart....
I am installing the new interior wiring harness and the dash instruments/gauges on my 69 L46 convertible. The AIM doesn't seem clear enough to me on the correct routing of the main harness on the left side of the steering column. As you can see from the picture below, I have two options. One would take the harness (where I have it currently) through the hole above the upper support rod and left of the steering column brackets. The other would route between the upper and lower support rods to the left of the steering column brackets. In either case I have to deal with the fresh air duct that seems to interfere with the harness routing. Any suggestions?
Thanks much,
Rich
Thanks much,
Rich
