67 Holley 2300 Problem - NCRS Discussion Boards
  • Patrick B.
    • August 31, 1985
    • 2003
    Re: 67 Holley 2300 Problem
    I think the easiest way to plumb a fuel pressure gage would be to replace the line to the rear carb (the longest line) with a rubber line and put a tee in it to a fuel pressure gage.
    • Stephen L.
      • May 31, 1984
      • 3162
      You don't need a "tee". You have two other carbs to run on... Just install a barb fitting in place of the rear carb line and a hose to your gage. You'll know in a matter of seconds what the fuel pressure is.....
      Good luck.
      • Patrick B.
        • August 31, 1985
        • 2003
        #18
        Good luck.
        Even better!
        • Danny P.
          • June 30, 2002
          • 344
          #19
          • Ralph P.
            • February 1, 1990
            • 253
            #20
            Thanks for all the good info ! So I'm understanding that a fuel pump problem is not likely..... All 3 bowls will be checked today !... I just can't understand how all 3 could be a problem...BUT "Murphy" has struck me before...
            • Danny P.
              • June 30, 2002
              • 344
              #21
              Pull the bowls off Ralph , remove the needle and seat with your finger move the float up and down slowly and see if there any binding in the up and motions
              • Ralph P.
                • February 1, 1990
                • 253
                #22
                Well, I've made no progress.... All 3 bowl floats are completely free of any hangup regardless of how I move the float side to side or up/down . Fuel valve needles move freely with no evidence of any trash on the seats. .....I Just gotta think this thru some more...
                • Danny P.
                  • June 30, 2002
                  • 344
                  #23
                  While your this far , check the floats are they brass give them a shake see if there not leaking may cause to stay down check if they float in some solution, if ok I would change the 3 needle seat I only use Holley product and you do have the stone filter in each Carbs. inlets
                  • Ralph P.
                    • February 1, 1990
                    • 253
                    #24
                    Brass in center only.... no fuel in any float. Had new Holley valves already, will see if I have more. Yes, stone filter is in all bowls . I'm done for today!
                    Appreciate all your analysis !! How could this happen if not thru the needle & seat ?
                    • Danny P.
                      • June 30, 2002
                      • 344
                      #25
                      Just doesn’t make any sense , your saying all 3 carbs. side plug gas pour out out on all 3 carbs. and you have 3 new Holley needle and seat , then the fuel Pump is more then 6psi anymore then 6psi will check off the needle and seat valve what kind pump are you using is it GM fuel pump , there are high volume Holley Mech. Pump that will give you 9 to 10 psi on special app. Just confirm the fuel pump pressure .
                      • Lawrence S.
                        • April 1, 1993
                        • 803
                        #26
                        The needle and seats have got to be contaminated to allow fuel into the bowls to the point you are describing. I can't imagine anything else.
                        • Timothy B.
                          • April 30, 1983
                          • 5196
                          #27
                          You have got to verify the fuel pump pressure, do the needle and seats have the little O rings at their waist. Suspect any new parts plus find a way to check those (non brass) and brass floats. A slightly heavy float could easily cause the high fuel problem.
                          Do you have a mitivac, it could be connected to the inlet line and pumped down when you raise the float to see if it holds a small vacuum. At least that will verify the needle/seat is sealing.
                          Those carburetors don't flood by themselves, you will find it.
                          • Ralph P.
                            • February 1, 1990
                            • 253
                            #28
                            OK.. Have removed 3 carbs; Checked all bowls for float binding or anything that could affect free movement. Brass float in center and plastic in ends are good with no absorbed fuel. I did bend each float tab slightly to give more valve adjustment possible to expose more threads on the valves. I verified no trash on needles or seats( went ahead & replaced 2 valves anyway since I had them).... verified a good o-ring on each & replaced in bowls. More threads showing now when adjusted slightly low for startup. I removed pump discharge nozzle , verified needle valve clean & installed point down, gaskets ok. Replaced power valve with a new Holley 6.5 . I'm going to take off the metering bodies on end carbs & replace gaskets while I'm in there. I'm leaning toward getting them back on & trying to start . I'll get a fuel pressure gauge tomorrow .
                            • Danny P.
                              • June 30, 2002
                              • 344
                              #29
                              Ralph, if it was my car I would first get 3 new brass floats , 3 new Holley needle and seat valve , and make sure you lube the small Oring when installing them and avoid anyTeflon tape and last make sure you got 6psi on fuel pump , power valve have nothing to do with your problem Block them or install stock power valve back in from kit .
                              • Ralph P.
                                • February 1, 1990
                                • 253
                                #30
                                UPDATE..... Got carbs back on, Checked & rechecked.... Tried to start & no luck. Engine fires & immediately shuts down ... good shot from squirter just after it dies. Now wondering if I have an ignition problem ? I swapped in an old coil ( same result) . Jumped ballast resister connections ..no change . I did notice that engine seems to start with key turned to "Start" and immediately die when released to "Run" ! I tried not releasing key when it started & engine seems to want to run. Guess I'm asking is this likely an ignition switch issue??
