Bolts with "L5" markings - NCRS Discussion Boards
  • David L.
    • July 31, 1980
    • 3310
    I have eight 5/16"-18 X 1" grade 5 bolts, full length threads, with "L5" markings on them that I removed from a 57-61 Corvette aluminum dual 4BB intake manifold which attached the 2 carburetors. I know the were not original since studs are the norm.
    Had anyone ever seen original Corvette, Chevrolet, or GM bolts with "L5" markings?
    Dave
  • Ed S.
    • August 6, 2014
    • 1388
    Re: Bolts with "L5" markings
    I think those bolts are used on the rear shocks - it is the upper bolt that goes through the frame - I know they are "correct" for a 64, not sure about other years of C2s.
    Ed
    • David L.
      • July 31, 1980
      • 3310
      Ed,
      The rear shock upper bolts, GM # 3824692, have 7/16"-20 threads. Do they have the "L5" markings?
      Dave
      • Ed S.
        • August 6, 2014
        • 1388
        Yes - my 64 has bolts marked L5, I believe the bolts are original. Off hand I do not recall the GM p/n - if necessary, I will check it for you in the AIM. LIC carries these bolts. LIC p/n is 51-54A, with L5 head marking.
        Ed
        • David B.
          • March 1, 1980
          • 690
          If those bolts are full length threads they certainly are not 3824692. They may not even be GM bolts regardless of head marking.
          • Ed S.
            • August 6, 2014
            • 1388
            David is correct, C2 "L5" rear shock bolts do not have "full length treads"
            Ed
            • David L.
              • July 31, 1980
              • 3310
              As stated in my very first post the size is 5/16"-18 X 1" with full thread length with the "L5" marking. This bolt size was used on the alternator adjustment brace. I have several in my 40-year collection with various head markings.
              Dave
              • David B.
                • March 1, 1980
                • 690
                Part #122017 zinc no argument on size etc.
