'63 Stripped Oil Pan Drain Hole - NCRS Discussion Boards
  • Norm B.
    • 360
    When draining the oil on my '63 in order to pull the pan and replace the gasket I had that "Oh s**t" moment when reinstalling the drain plug when I just knew it was not going to snug up. My first thought for repair is Helicoil but are there any other or better options? It's a 340hp oil pan and the engine is currently out of the car, on a stand, and the oil pan was coming off anyway.
    Norm
    Golf is for those who can't play​ hockey.
  • Harry S.
    • July 31, 2002
    • 5346
    Re: '63 Stripped Oil Pan Drain Hole
    Norm
    Potential solutions:
    1) As you said a helicoil
    2) Purchase a larger drain plug that will self tap a new set of threads into the pan
    3) What is on the welded on the inside of the pan, a nut plate or a nut? Grind off the nut or nut plate and spot weld a replacement.
    I had the same problem on my 63. I ground off the nut plate and replaced it with an NOS nut plate.
    • Peter M.
      • May 30, 2013
      • 361
      Norm,
      There should be a 1 and 3/8" by 7/8" flange that was spot welded inside the pan that the plug screws into. They were available from GM for service, I think the part number was 3723008.
      I don't know if your FLAPS has them. I may have one in my tool box if you need it.
      Kind regards
      • Mark E.
        • April 1, 1993
        • 4611
        Originally posted by Peter Miller (58508)
        Norm,
        Kind regards
        What an impressive car guy- knows the part number AND may have one in the toolbox.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
          • 43289
          Norm,
          Kind regards
          Peter------
          The part number was GM #3723008. However, it was discontinued without supersession in July, 2013.
          • Harry S.
            • July 31, 2002
            • 5346
            Here is what it looks like.
            • Harry S.
              • July 31, 2002
              • 5346
              Installed...
              • Peter M.
                • May 30, 2013
                • 361
                Thanks Mark and Joe.
                • Mark E.
                  • April 1, 1993
                  • 4611
                  The design of #3723008 highlights why these things leak. It's not enough for the threaded hole to be sealed. The flange of the drain plug must also be sealed against the surface of the pan.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                    • 11698
                    You might also look at a Time-Sert rather than a Heli-Coil.
                    Better product.
                      • 43289
                      Mark------
                      The seal at the oil plug flange is the only seal that matters. Unfortunately, despite repeated attempts GM never came up with a seal that worked 100%.
                      GM #344690------metal and asbestos composition
                      GM #513975------nylon
                      GM #3765650----nylon
                      GM #3921989----nylon
                      GM #14079550--rubber/tin
                      GM #14090908--rubber/tin
                      Later with metric thread plugs:
                      GM #3536966----rubber; used with compression controlled plug GM #11562588
                      NONE of the above work to 100% prevent oil seepage at the plug. NONE!
                      Below are photos of the GM #14090908 which is the latest and currently available seal for SAE thread plugs. Also shown is the GM #3536966 and with the GM #11562588 plug.
                      • Mark E.
                        • April 1, 1993
                        • 4611
                        Mark------
                        And this explains why it's so common the threads strip- folks trying to stop the leak by over-torquing.
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                        • Dick W.
                          • 10483
                          I have used Loctite PST on the threads of oil plugs for years. Might leak somewhere else but not there.
                          Dick Whittington
                            • 43289
                            Dick-----
                            I've tried that, too. It did not work for me. And, the seepage was definitely originating from the plug.
                              • 15640
                              All Corvettes mark their spot.
                              Just like they all leak.
                              Not to worry.
