sway bar - NCRS Discussion Boards
sway bar
  • Carmelo P.
    • May 9, 2016
    • 54
    sway bar
    67 327/350
    Ready to order new sway bar bushings and links, I checked the bar diameter.
    Turns out it measured 7/8....ok to leave as is or look for a 3/4 bar?
    thanks...
  • David H.
    • June 30, 2001
    • 1558
    Re: sway bar
    Originally posted by Carmelo Paramonte (62401)
    67 327/350
    thanks...
    Carmelo
    What are your plans for this car?
    If your concern is Flight judging, "Anti-roll bar, links & bushings" are 5 points Originality and 5 points Condition. i.e. if your car showed up without any sway bar, bushings, links, etc, you would loose a maximum of 10 points out of 4500 points possible.
    Likely you would loose 20% for Configuration or 1 point (20% of 5 Originality points) - under CDCIF given bar is 7/8 vs 3/4.
    You need to assess cost of replacement sway bar vs picking up ≈1 judging point.
    If you're happy with your current setup, I'd leave it alone - just replace bushings and links.
    Dave
    p.s. BTW does your car have a rear stabilizer bar?
    • Carmelo P.
      • May 9, 2016
      • 54
      Re: sway bar
      No rear stabilizer bar...not being judged, thought it would have adverse effect on drive ability being its for a big block..
      Thanks...
      • David H.
        • June 30, 2001
        • 1558
        Re: sway bar
        Thanks...
        Shouldn't be a problem. My 1980 with FE7 suspension has a 1 1/8" front bar.
        • Carmelo P.
          • May 9, 2016
          • 54
          Re: sway bar
          the car will ride stiffer then?
          • Richard G.
            • July 31, 1984
            • 1718
            Re: sway bar
            Sway bars do not typically affect the ride much.
            Big difference is the cornering ability.
            The sway bars on modern cars are much beefier than anything from the 60's.
            For example The 1990;s Ford Escort GT has a sway bar that looks to be 1-1/4.
            • David H.
              • June 30, 2001
              • 1558
              Re: sway bar
              Gymkhana Suspension option FE7 (1974-1982) included stiffer sway bar and springs. Some folks removed rear sway bar to improve ride. Serves as anti-roll bar to quiet body lean in corners. Probably you would notice differences on a track, but not much in day-to-day driving.
              • Carmelo P.
                • May 9, 2016
                • 54
                Re: sway bar
                Thanks to all...
