Re: Turn Signal Cancelling
Jerry,
Sounds like you are referring to the horn contact connector spring (I think that's what it is called). This small contact and spring allows a slight downward tension so the horn contact stays in constant contact with the brass ring that is part of the upper steering column bearing when you turn the wheel left/right.
The horn relay ground path runs through the steering column up to the horn button contact and completes (makes) when you push down on the horn button. The horn button connector and spring simply keeps the top hub and bottom steering column assembly ground path together.
The gap is set between the bell and hub (.090 +-) by sliding the bell upward and snugging the side screw/wedge after the hub is tightened to the shaft so the hub does not rub on the bell when turning the wheel. The last adjustment is to the cable/switch down low on the column after the top gap is set.
Jerry,
