Fuel Pump Swap - NCRS Discussion Boards
Fuel Pump Swap
  • Patrick B.
    • August 31, 1985
    • 2003
    Re: Fuel Pump Swap
    Originally posted by Richard Landeira (7989)
    Since these pumps seem to fail unexpectedly, I'd like to have a replacement one on hand for when I'm on a road trip. Is there a generic one I can source from either NAPA or Rock Auto that will fit all three of my C-2's ('63 300hp, '67 300hp, '67 427/435)?
    Thanks in advance.
    Ric
    The 63 and 67 327 pumps would both bolt up to the same block but are of a different design so it is unlikely the outlet fitting would be in the same location. The big block pump would not even bolt up to a small block.
    • Frank D.
      • December 27, 2007
      • 2703
      Re: Fuel Pump Swap
      Originally posted by Harry Sadlock (38513)
      Thanks all. I'll give it a go. Now taking off the wheel on a four post lift will be interesting.
      I have a small bottle jack that just fits under the frame rail aft of the wheel and I can pump it just enough to get the tire airborne and slip a block made of wooden 2x4s screwed together to rest the frame on temporarily..while leaving the bottle jack in place with a bit of tension on it.
      • Harry S.
        • July 31, 2002
        • 5330
        #18
        Re: Fuel Pump Swap
        I like that......
        • George C.
          • November 1, 2001
          • 568
          #19
          Re: Fuel Pump Swap
          Ric,
          I haven't seen any answers on a good source for a rebuild kit.
          I ended up ordering a new pump for the current problem, but still plan to get a kit and rebuild the old pump, if we get a recommended source. Some of the Corvette Parts houses have them, but they are pretty pricey.
          George
          • Harry S.
            • July 31, 2002
            • 5330
            #20
            Re: Fuel Pump Swap
            Try ----> http://arthurgouldrebuilders.com/contact.html
            I believe for $100.00 they restore, rebuild and pressure test your pump. Give them a call for current pricing. If it's still $100, not a bad deal
            • Frank D.
              • December 27, 2007
              • 2703
              #21
              Re: Fuel Pump Swap
              Originally posted by George Cooper (36908)
              Ric,
              George
              I guess you didn't see my Paragon post; I used their kits in three original 4657 pumps with no issues, I'd bet most the big vendors carry the same ones; ethanol resistant soft parts and proper diaphragm.
              But yes you can always use one of those "less pricey" off shore Chiwanese kits with the overly stiff diaphragms that'll jam 8 psi fuel into your carbs.
              Been there, done that...
