steel body mount supports - NCRS Discussion Boards
  • Louie R.
    Infrequent User
    • December 1, 1996
    • 4
    Hi , I'm installing some new steel body mount supports on my 65 (the ones that are riveted to the underside of the body) what color should the be ? Thanks for the help
  • Tom D.
    • September 30, 1981
    • 2137
    Re: steel body mount supports
    GOOD Question. See other discussions of the A O Smith green (search for "zinc chromate") metal parts.
    Answer: I would assume black, especially if you have an S (for Saint Louis) body number on the trim tag.
    I am going with black on my current A - (for A O Smith, Ionia Michigan Made) body. Will later add some under-coat spray, also black, on the side that shows behind the rear wheel.
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • David H.
      • June 30, 2001
      • 1544
      Louie,
      Years apart, but here is a color photo from December 1980 - those metal parts were black.
      Dave
