C1 59 wiper motor - NCRS Discussion Boards
C1 59 wiper motor
  • Geert W.
    Infrequent User
    • March 20, 2015
    • 11
    C1 59 wiper motor
    Hi all,
    I'm cleaning/repairing the wiper motor of my 59 vette.
    Last summer I had some issues with it and saw that the resistor was getting hot and was producing some smoke, now it seems to be broken.
    I can't find a replacement in the catalogues online so guess I will need to replace it by an modern resistor but don't know the value of this one, ohm and Watt, is there somebody here that knows these values?
    Have already checked servicing and assembly guide without succes but might have overlooked it.
    Thx
    Geert
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11324
    Re: C1 59 wiper motor
    Geert, Here is a reference internet post with the value that appeared to work.
    https://www.corvetteforum.com/forums...post1585531961
    • Geert W.
      Infrequent User
      • March 20, 2015
      • 11
      Richard,
      thx for the reply, found it, just can not find a resistor with that values here and have no clue what tolerance i can allow on this... will continue the search 😀
      • Dan B.
        • July 13, 2011
        • 545
        Working on a wiper motor that also needs a new resistor (no slow speed) and was wondering what if anything you might have found? The original is a 30 OHM resistor and size (in the case) is a constraint. I have not found the exact resistor referenced in the post (from 2013) currently, but see a few that are very similar, but with slightly different values.
        Possibly someone who had theirs rebuilt and this part replaced could share that info with us.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11324
          Dan, Maybe Paul Maxwell has the info you need. He restores these. Iirc he advertises in the Driveline.
          • Geert W.
            Infrequent User
            • March 20, 2015
            • 11
            Dan,
            I did eventually found a resistor in France with a company that sells components for speakers.
            Will see this evening if I can find the details.
            But after installing it I didn't got the desired result, wiper was working but without power, probably more things wrong than just the resistor.
            So I decided to have it restored so I've send it to Steve Hackle to be overhauled.
            Unluckily he has some health problems at the moment, but hope to have it back soon.
            • Dan B.
              • July 13, 2011
              • 545
              Originally posted by Geert Waem (61047)
              Dan,
              Geert,
              Thanks for your reply. I have the motor running smoothly and the switch mechanically functioning, so I know it works on and off at high speed and parks properly.
              I ordered some resistors that I think will work if they fit. Got the old one out, did not need to further disassemble the switch. Here is a photo on the work bench of the repair in process.
              • Dan B.
                • July 13, 2011
                • 545
                That's a thought if I can't make it work. I matched the OHMS and wattage (I think) so it's a question of size now.
                • Dan B.
                  • July 13, 2011
                  • 545
                  Just to update the outcome for anyone interested, I found a suitable resistor and installed it on the switch and all is working perfectly now. I test ran the motor for several minutes and there were no issues.
                  These switches are very fussy though and I had to spend some additional time adjusting it to get it to consistently park from the slow speed. I enjoy a rainy day bench project (once in a while ), but time wise especially if you don't like to do this stuff, it's better to send the motor out for $200 or so. Also, as a bonus, I was also able to get the windshield wiper coordinator that it came with operating again after disassembling. A good day!
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11324
                    Dan, Just a word of caution. Bench test with the cable attached.
                    • Dan B.
                      • July 13, 2011
                      • 545
                      Rich, had not thought of that. I tried to duplicate the minimal range it can move when installed and still get it to work properly. I think that is what you are cautioning about. I'll double check it. Thanks for the suggestion!
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11324
                        Yes I had a motor rebuilt by one of the pro shops and it wouldn't shut off. I had to readjust the switch contacts after installing it. Pulled it out again, disgustingly, pulled cable out of the dash, then hooked it up on the bench.
                        It wouldn't shut off.
                        After adjusting switch contacts again per ST-12 procedure, all good. Back in the car and it was fine.
