Looking at 70 big block. Requesting help where to verify VIN & engine numbers - NCRS Discussion Boards
  • Patrick B.
    • August 31, 1985
    • 2003
    Re: Looking at 70 big block. Requesting help where to verify VIN & engine numbers
    The same casting was used for a 2 bolt and 4 bolt block. The only difference was the machining and bearing caps.
      • 15616
      Pat
      Are you saying the two bolt case had the openings for the oil cooler fittings?
      • Patrick B.
        • August 31, 1985
        • 2003
        #18
        Pat
        The two bolt blocks had the bosses cast for both holes just like the 4 bolt blocks. The only difference was that hole over the oil filter was machined with a smaller pipe thread than the hole in the 4 bolt block, and there was no machined hole in the forward boss on the 2 bolt blocks. If the castings were not the same, they would not have the same casting number.
        • Kenneth B.
          • August 31, 1984
          • 2091
          #19
          You are correct. Every 427/454 I ever saw had the 2 bosses as you describe. There would be no reason to have another pattern for a 2 bolt & a 4 bolt casting. They are just machined different. PS I have seen one that was being made a 4 bolt in a engine machine shop. Not that hard to do.
            • 15616
            #20
            So the 4-bolt case can be externally discerned by the hole that is tapped and plugged above the oil filter?
            • Edward B.
              • March 29, 2013
              • 691
              #21
              See attached
              Ed
                • 15616
                #22
                Originally posted by Edward Bertrand (58273)
                See attached
                Ed
                Well done Ed.
                NO, that would be too simple. There are differences in the cylinder case casting, the most obvious of which is above the oil filter mount.
                WRONG, my bad. I don't know what I was thinking, but it obviously wasn't correct. Thank you Patrick et al
                I think someone has photos that will be worth much more than my explanation. There were tapped holes in the four-bolt block just above the oil filter presumably for lines to an engine oil cooler. These tapped holes were sealed with pipe plugs in the absence of an engine oil cooler.
                A picture is worth many words. Thank you again Ed.
                • Dick W.
                  • 10483
                  #23
                  See attached
                  Ed
                  And there are a few two bolt blocks that have had post production machining and have the plugs there. I know nothing
                  Dick Whittington
                  • Edward B.
                    • March 29, 2013
                    • 691
                    #24
                    That's correct Dick. Any competent machine shop can add them therefore this isn't a definitive indicator of a 4 bolt main block.
                    Ed
