Wcfb - NCRS Discussion Boards
Wcfb
  • Greg D.
    • June 30, 2004
    • 62
    Wcfb
    What is the height difference between the 1960 Chevrolet passenger WCFB and that of a 1960 Corvette. I'm told that the carb for the Corvette was different by a shorter base
  • Joseph L.
    • July 26, 2012
    • 162
    Re: Wcfb
    Hi Greg
    The single four barrel base is thicker than the dual four base. If you have them in your hands it is very noticeable. I do not have the measurements but when I got my car, the rear carburetor had a single four barrel base and sat higher. You can see the difference. The intake manifold mounting surface is higher by a very small amount but not as much as the difference in the photo of the carbs before they were restored to with both having thin bases.
    Somewhere I have the part numbers for both. They are cast into the bases. Contact me.
    Joe
