1971 T3 Headlights - NCRS Discussion Boards
1971 T3 Headlights
  • Kenny S.
    Infrequent User
    • May 23, 2012
    • 1
    1971 T3 Headlights
    My car happens to be late enough in the build series that it has the T3 with the logos at the bottom of the bulb. They're virtually impossible to find. Any suggestions on how to deal with this from a judging standpoint? Or a source for them?
  • Bob D.
    NCRS Shipping Data Report Manager
    • April 30, 1996
    • 795
    Re: 1971 T3 Headlights
    Try David Sokolowski. He advertises in the Driveline.
    • Jeffrey S.
      • May 31, 1988
      • 1900
      Kenny,
      The easy way out is to use a set of the 68-71 lined triangle bulbs. I don't believe that any judge would deduct for these on any 71 no matter how late the build date late. These are readily available and far cheaper than the one year only 72 bulbs. BTW- I sent you an email.
      Jeff
      • James G.
        • August 22, 2018
        • 808
        FWIW - My 71 was built 18 from the end and has a mix of low T3 and lined Triangle and received zero deduct at the 2019 Nationals. just don't buy repros with the DOT on the edge... that will get you some deducts.
        James A Groome
        • Mike E.
          • February 28, 1975
          • 5141
          My 71 30k mile car 148 from end of production had all four with the low T3. The car sat for a dozen years before I acquired it. I hooked a battery to it and promptly burned out two of the four. Found some in the box at Carlisle, and put a bead of silicone at the base of the contact before I fired those up.
          • Dave S.
            • August 31, 1992
            • 2930
            From what I have seen over the years the 72 style T-3's began to show up as early as April/May 71 but the 68/71 style was used through the 71 model year. My last week of production 71 had 3 late style and 1 of the early style.
