C-2 1965 Fuel Pump Push Rod - NCRS Discussion Boards
  • Ed D.
    • December 1, 2003
    • 207
    Re: C-2 1965 Fuel Pump Push Rod
    Thanks for the tip ! ... Removing that plate made everything easier to see and made the rod much more accessible. I should have done this in the first place ! I'll be able to get rolling as soon as my new gasket arrives. With the photos you can see the position of my push rod. Perhaps I should tweak its position ?? Thanks ALL !
      • 43248
      Ed------
      I think the push rod position should be adequate for pump installation.
      • William F.
        • June 9, 2009
        • 1364
        #18
        and putting the hold in bolt in before you removed old pump?
        • Ed D.
          • December 1, 2003
          • 207
          #19
          Not understanding your question . The hold in what bolt ?
          • William F.
            • June 9, 2009
            • 1364
            #20
            The longer bolt you substitute for the short bolt in hole in front of block to hold rod in place while you install pump.
