1958 windshield moved - NCRS Discussion Boards
  • Jim M.
    • August 7, 2019
    • 14
    Anyone ever had a problem with the windshield coming out of the seal on top after car was lifted?
  • Bruce W.
    • June 30, 1997
    • 360
    Re: 1958 windshield moved
    Hi Jim,
    I had that problem on my 57. A real head ache to fix. Whoever installed your top made it too tight. Having said that You have to always to disengage the top when lifting the car on a lift. The frame on these old cars will flex and create a real problem. The windshield will have to come out to fix it. i am told that the repo windshield's are a little smaller. I had to have a round piece of rubber installed on the bottom of the windshield to fix my problem. A REAL headache!!! Hope this helps. Patience My friend. Anything can be fixed!!
    Bruce
    • Jim M.
      • August 7, 2019
      • 14
      Bruce, I"ll see if it moves after loosening the top, Thanks for the advice.
      • Mike M.
        • May 31, 1974
        • 8400
        there exists a urethan based windshield setting product. it binds the too thin repo glass to the rubber weatherstrip. it cured the problem on both our 57's with repo windshields. I don't recall the manufacturer of this product. perhaps someone else can identify the maker. mike
        • Mark S.
          • July 31, 1983
          • 660
          3M Windo-Weld Super Fast Urethane #08609 or Dow Betaseal U-418 primerless auto glass urethane adhesive. Use gloves, otherwise your hands will be black for a week and a half like mine were when I used it.
          • Jim M.
            • August 7, 2019
            • 14
            Thanks for the information.
