1970 Round key re-key spare lock or glove box ????? - NCRS Discussion Boards
  • Bob B.
    • January 31, 2007
    • 524
    The round key on my 70 is MIA, Do I buy a spare tire lock with key (repro) and rekey the rear storage box
    or get a lock smith to key the storage box and then rekey a used spare lock to match the rear storage box?
    THANKS,
    Bob
  • Jeffrey S.
    • May 31, 1988
    • 1882
    Re: 1970 Round key re-key spare lock or glove box ?????
    Bob,
    Unless I am misunderstanding your situation, there is no reason to buy any new locks if you are just missing the key. Any locksmith can take the lock cylinder out and get the key number and simply make a new key.
    Jeff
    • Bob B.
      • January 31, 2007
      • 524
      Originally posted by Jeffrey Salz (13182)
      Bob,
      Jeff
      That sounds way too easy- Thanks, I have a very good lock guy here in Palm Desert will give it a try
      • Bill L.
        • February 1, 2004
        • 1403
        Removing the storage compartment lock is easiest by far.
        • Jeffrey S.
          • May 31, 1988
          • 1882
          And it's also very easy to remove the cylinder from this lock without a key. Takes about 10 seconds. The spare tire lock needs a key to remove the cylinder.
          Jeff
          • Bob B.
            • January 31, 2007
            • 524
            OK 10 seconds to remove storage box lock I sure don't see any key number a lock shop can use.
            So, now buy a used spare lock and take them both to the lock shop? I will let you know how that goes
            Looks like its about time for a trip to David Sokolowski's LA,CA warehouse- when you NEED a part, his inventory
            is incredible everything !
            Thanks Bob
            • Jeffrey S.
              • May 31, 1988
              • 1882
              Bob,
              The cylinder needs to be removed from the case. That's very simple. I have taken many out without a key. I'm working from memory here. There are 2 openings behind the bezel. One will look empty. In the other you will see one shiny steel tang and some brass tangs. They are all spring loaded. First depress the steel "locking" tab. The cylinder will come out slightly. Then depress each of the brass tabs (these are the tumblers) one by one and the cylinder will come out. Work slowly and carefully so as not to allow the tumblers to go flying out. The numbers will be stamped in this cylinder. If this is beyond your comfort level, then bring it to a locksmith and they can easily do it.
              Please don't hesitate to call me at 248-860-1157 and I can walk you through it.
              Jeff
