Lower Fan Shroud - NCRS Discussion Boards
Lower Fan Shroud
  • Howard H.
    • January 10, 2007
    • 142
    Lower Fan Shroud
    I purchased a new reproduction 4 piece fan shroud for my may built 58 a couple years ago and am finally getting around to installing it. In the Noland Adams book there is a pretty good picture of a 56-57 lower shroud mounted to the frame showing two bolts attaching the lower center section to the front cross member. I couldn't find anything for a 58. The shroud I bought does not have holes for mounting to the cross member. Should it have? The cross member does have threaded holes that looks to be where it would mount. If it does, what type fastener is used? Thanks for any help
  • Mike E.
    • February 28, 1975
    • 5141
    Re: Lower Fan Shroud
    58 does not mount to the crossmember.
    • Howard H.
      • January 10, 2007
      • 142
      Thanks mike;
      I wanted to make sure before I drilled mounting holes.
      Howard
