Is my frame a C2 or C3 - NCRS Discussion Boards
  • Barry J.
    • May 28, 2009
    • 61
    Do I have a C2 or C3 frame?
  • Tim G.
    • March 1, 1990
    • 1413
    Re: Is my frame a C2 or C3
    Looks like a C2 between 65 and 67. The battery location and indentation for the harmonic balancer are the clues I saw. Others may be able to narrow it down to the exact year.
    • Donald L.
      • November 1, 1981
      • 141
      You have a 1966 frame. You can tell by the center cross member notches where it is welded to the main rails.
      • Barry J.
        • May 28, 2009
        • 61
        • Chris D.
          • November 1, 2002
          • 198
          Yes, if original, rear bar would indicate big block. Any chance the VIN derivative stamps on frame and engine still match?
          • Terry B.
            • August 31, 1999
            • 607
            I thought in early 1968 production, the remaining C-2 frames were still being used up in early C-3's production. Then in mid 1968 production (as early as mid January possibly) the true C-3 frame came on line with the 2 angle braces being welded between the rear dog leg and the differential cross rail. My big block 68 with the build date of early December '67 did not have the angle bracing. Later 1968 cars and after had the angle brace reinforcement.
            Terry Buchanan
            Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
            Corvettes Owned:
            1977 Coupe
            1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
            2003 Electron Blue Coupe
            2019 Torch Red Grand Sport Coupe
            • Barry J.
              • May 28, 2009
              • 61
              • Mark M.
                • October 21, 2008
                • 342
                Appears to be early 66 big block convertible.
                • Mark M.
                  • October 21, 2008
                  • 342
                  non air condition
                  • Lawrence M.
                    • February 1, 1995
                    • 404
                    Terry,
                    I don't think 67 frames could be used for 68 production. The rear frame rails at the gas tank location are of a different configuration than 68 frames. The bracing you mention was just improvements made to C3 frames as problems were discovered .
                    Larry
                    2002 Z51 Convertible
                    1969 L46 Convertible
                    • Dave H.
                      • August 17, 2010
                      • 47
                      I was under the impression that the wheels on C3s were wider, dictating that the rear ladder section be more narrow to accommodate. I do not have my frame dims to verify.
                      • Lawrence M.
                        • February 1, 1995
                        • 404
                        Dave,
                        That could very well be, I do not know. I do know the C2 rear frame section kind of sweeps down while the C3 sweeps up.
                        Larry
                        • Keith B.
                          • September 15, 2014
                          • 1600
                          that looks to be a C3 rear bar as it looks to have a hump at the ends. C2 bars are straight
                          • Eric C.
                            Infrequent User
                            • April 8, 2019
                            • 1
                            Given the hole in the trans cross member, i'd say not 67 as earlier parking brake cables went through that hole.
