1965 327/300 Fuel Pump Removal (no AC) - NCRS Discussion Boards
  • Ed D.
    • December 1, 2003
    • 207
    I am the process of replacing my fuel pump. The pump looks to be buried with heater hose, alternator etc. ! I have fairly large hands. How is everyone gaining access to this fuel pump ? Are you removing the alternator and heater hose ?? ANY tips or suggestions are welcome !! Thanks ...Ed
  • Leif A.
    • August 31, 1997
    • 3646
    Re: 1965 327/300 Fuel Pump Removal (no AC)
    Ed,
    Are you attempting this task from the top side? I've never done it from the top but I would think you would need to remove anything in the way to access the pump. From the bottom, much easier. Don't forget to have the engine at TDC and remove the bolt in the hole in the front of the block adjacent to the fuel pump rod, inserting a longer one to hold the rod (gently) up and out of the way when installing the new pump.
    Leif
    • Ed D.
      • December 1, 2003
      • 207
      • Frank D.
        • December 27, 2007
        • 2703
        On my '63 I work through the PS wheel arch after removing the tire with a long extension and wobble joint...MUCH easier...and I've done it several times..
        • Leif A.
          • August 31, 1997
          • 3646
          Originally posted by Ed Doone (40992)
          Thanks Leif ! I was going to remove it from the top side. I looked from underneath ( 65 sits on BendPak lift ) It didn't look any easier! Maybe if I take off wheel/tire. ….. Ed
          This and a socket u-joint connection will make the job much easier.
          Leif
