1967 390hp choke cable thru firewall and carb attachment - NCRS Discussion Boards
  • Dave K.
    • January 24, 2013
    • 278
    Does anyone have a picture or location of where the choke cable comes thru the firewall? Also where on the carb is it attached?
  • Tom B.
    • March 1, 2002
    • 140
    Re: 1967 390hp choke cable thru firewall and carb attachment
    Never heard of a choke cable on a 67 Vette ?? The engines had an automatic well choke with a rod and thermostatic spring.
    • Jim D.
      • 2885
      The only Corvettes that I'm aware of that used a manual choke were those with the Blue Flame 6 cyl.
      • Dave K.
        • January 24, 2013
        • 278
        0.jpg here is the pic
        • Enzo C.
          • January 12, 2012
          • 534
          Screwed to the intake on the right side with a Phillips screw
          Enzo Colosimo
          Ncrs Ontario Chapter Chairman 🇨🇦
          ENZ-Z06/67
          • Jim D.
            • 2885
            It's an aftermarket addition.
            • Dave K.
              • January 24, 2013
              • 278
              Jim. So the original Holley carburetor model 3811 for a 1967 390hp did not have a choke cable? The reason i'm asking is because i replaced the old carb that was on the car with an original 3811. The old carb (was a holley but can't remember the model number) had this choke cable on the right side of the carb and the pull out carb lever was attached to the underside of the instrument cluster right underneath the lighter.
              • Jim D.
                • 2885
                The choke on the original carb. was operated by a thermostat coil mounted on the intake manifold.
                • Keith B.
                  • September 15, 2014
                  • 1592
                  here is a picture showing how the choke set up works
                  • Dave K.
                    • January 24, 2013
                    • 278
                    Is this thermostat coil needed? I bought a 3811 carb and it does not have this coil. During judging do they look for it??
                    • Keith B.
                      • 1592
                      It’s needed for proper cold starts and warm up. Yes it’s a judged item. There should be choke on the carb but the per shown in Jim post is a separate item
