Tank Sticker Puzzle - NCRS Discussion Boards
Tank Sticker Puzzle
  • Randy M.
    Infrequent User
    • February 25, 2019
    • 18
    Tank Sticker Puzzle
    I have the tank sticker for my 67 small block and it has an entry at the very bottom, right below "TINTED GLASS", that says "SEQ F 25". I've seen other similar codes like this but have never been able to find any reference information explaining what they mean. I've checked the ECL code section in Noland Adam's book and can't find any mention.
    Can anyone tell me what "SEQ F 25" means?
    Does anyone have a reference describing all of these numbers?
  • Leif A.
    • August 31, 1997
    • 3619
    Re: Tank Sticker Puzzle
    Interesting question...I'll be watching for the answer. My '67 tank sticker (with power windows) does NOT have the notation.
    Leif
    • Michael J.
      • January 27, 2009
      • 7106
      Neither of my '67s have that, but one has "PLS RUSH" on that bottom line. Maybe that was for special handling so something like that? The assembly line may have known what that sequence number meant.
        • 15583
        Mike's esponse rings a bell. If the letters SEQ stand for SEQUENCE this may be an indicator of the build sequence for your car. Have you found the "body build number" on the passenger side toe board on the enging side -- of in front of the gas tank on the back bulkhead? Or in either of the doors?
        Before the car got a VIN assigned to it it was assigned a sequence number for scheduling purposes. Any chance your car was built on or about June 25?
        • Brian M.
          • February 1, 1997
          • 1838
          That car should be in the 7000 vin area?
          • Randy M.
            Infrequent User
            • February 25, 2019
            • 18
            The Body Job number read on passenger side foot well is: 494
            Last 3 digits of VIN are 726 and 726-500=226, thus penciled number on tank sticker of 225 is consistent with the VIN.
            Car was built early Jan and left the assembly line on 1/10/1967, so I don't think the "SEQ F 25" number has anything to do with assembly completion date, body shop number, or tank sticker build sequence number, etc.
              • 15583
              Looks like I struck out.
                • May 31, 1974
                • 8376
                Terry: moving from c-3 to c-2, in your case, dictated a strike out. saint Michael
                  • 15583
                  You are right St Michael. I should have known better. I will return to my own choir.
                  • Brian M.
                    • February 1, 1997
                    • 1838
                    Tank sticker for VIN 7471 has the same order date, date of production and Zone #.
                    SEQ F 29 at the bottom.
                    • Mike E.
                      • February 28, 1975
                      • 5136
                      Attached is a build sheet from a 72. In the far lower left, you will see SEQ B290
                      I have no idea what it means. This was a base motor 4-speed coupe.
                      • Randy M.
                        Infrequent User
                        • February 25, 2019
                        • 18
                        Interesting that this notation is seen on other 67s and now on a 72. It clearly means something and I would think that someone would know the meaning. Perhaps an old timer that worked at the factory might know (if one is still present on this forum)?
                        • Ronald R.
                          • May 31, 1989
                          • 670
                          107726 at bottom is correct i assume
                          • Mike E.
                            • February 28, 1975
                            • 5136
                            Let's try to attach again!
                            • Randy M.
                              Infrequent User
                              • February 25, 2019
                              • 18
                              Yes, that is the cars VIN.
