1960 high horse fuel injection - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    Of the three FI units 250-300-320, do ither the 250 or 300 units have a finned top? I know the 320 has a flat top and will the 250 and 300m unit work for a May-1960. Maybe good ole JD can chime in. Thanks in advance. Jerry
  • Jim L.
    • September 30, 1979
    • 1816
    Re: 1960 high horse fuel injection
    The 7250 and 7300 units which have crossed my bench have had the finned doghouses.
    • Don H.
      • December 1, 1981
      • 1491
      Jerry, The 250 & 300 units have the ribbed plenum, only the 310 & 320 units (for 1960) had the flat top. I believe the 320 unit is much more common for the 290 HP engine but I am certainly not an expert. I am not familiar with a 300m unit, there is a 300R listed for 1959 low HP. Good luck, Don H.
      • John D.
        • December 1, 1979
        • 5507
        Jerry
        Hi Jerry, Look on page 174 of the new 1958-1960 manual. You already have the answer but I will repeat some of it.
        Plenum styles.
        I would not expect to see the early finned units on a May car. THe May HHP had the 7017320 flat top unit.
        FYI info and others. 7017310 unit. About 8 were made. I have only restored one original 7017310. They are a LHP unit.
        I restored an original 7017310 in the late 80's or so. Was on a car from Texas.
        To recap: You need a flat top 7017320 unit.
        Take care, John
