Late 57 with a 4800 Fuel Injection - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    Car built August 23 with a 4800 Fuel injection unit . How many points would you loose .Any body know were there is a 4960 unit
  • Jim L.
    • September 30, 1979
    • 1817
    Re: Late 57 with a 4800 Fuel njection
    There is no difference between a 4800 and a 4960 other than how the two were calibrated at the factory. If you have a good working 4800 unit, I wouldn't recommend removing it just to install a 4960. I don't know about judging points.
    Jim
    • Gary C.
      Administrator
      • October 1, 1982
      • 17940
      4800 units are okay up to VIN 5584 - is your VIN higher?
      Gary
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Dan P.
        • December 1, 1990
        • 683
        yes made in the last week of production
        • Mike M.
          • May 31, 1974
          • 8408
          get with John degregory for a 4960 Rochester tag and pair of rivets. mike
          • Jim L.
            • 1817
            You need slightly more than that.
            The Fuel Meter needs to be stamped "962". Bonus points for not showing a previous "802" stamping.
            • John D.
              • December 1, 1979
              • 5507
              One time years ago at a Pittsburgh Tri Chapter chapter seminar I had a table set up with an original 7014800 unit and an original 7014960 unit.
              From a few feet away they look the same. But close up reveals number differences.
              Look in the'57 Judging manual. Look at the new 58-60 manual for the differences.
              Numbers on the fuel meter are not the same.
              7014800 fuel meter is stamped 802. Nozzles are Q's or R's.
              7014960 fuel meter is stamped 962.. Some of the fuel meters are overstamped. 962 right over the 802. Nozzles were S13.
              Refer to the judging standards manual for deductions. I am going to guess Dan that you will lose 50% with the incorrect unit. But others know more.
              7014800 is a low HP unit although we have heard a few were installed on a HHP engine. John
              • Joseph L.
                • July 26, 2012
                • 162
                Hi Dan
                Back to the original question, with a complete and typical 4800 on an Aug. 23 car, it could expect up to 20-40% of the 30 originality points. It might be for config and date.
                Joe
