67 big block hood - NCRS Discussion Boards
67 big block hood
  • Mel S.
    • August 31, 1992
    • 264
    67 big block hood
    i want to paint the stinger on my yellow 67 BB hood black. Presently, the complete hood is painted yellow. A couple of questions:
    1. What color black should it be - i.e. flat, semi-gloss gloss or ???
    2. where can I get the correct layout or template for the hood?
    3. When you open up the hood, is the center of the body (under the hood) painted black of the body color?
    Mel
  • Keith B.
    • September 15, 2014
    • 1604
    Re: 67 big block hood
    1) Tuxedo Black (paint code 900)
    2) paragon, LIC and others sell a template that is very close
    3) its all black expect the outer edge is body color
    • Mel S.
      • August 31, 1992
      • 264
      Thank You very much
      Mel
      • Stephen L.
        • May 31, 1984
        • 3163
        ONLY the hood has black and also the forward point. The area near the windshield is body color. Body color also on the rear underside that protrudes over the cowl.
        • Gary J.
          • April 1, 1980
          • 1246
          Use the AIMs for the layout. It would also beneficial if you had some pictures. If you are planning on having your car judged, if you get this wrong it is a 32 point deduct!
          • Stephen L.
            • May 31, 1984
            • 3163
            purchase some 5/16" striping tape to "mask" the narrow body color stripe. Lay out the entire stripe with the hood installed to get the transition across the front opening correct. The raised area stripe does NOT follow the body line.
            • Carl S.
              • April 21, 2017
              • 18
              Also, according to an NCRS tech session we had up in PA a few years ago, the last inch or so of the point of the outer stripe (closest to the front of the car) was painted by hand on the factory line.
              A line worker actually sat there and completed the last inch with a brush. We were shown examples of original hoods and sure enough, if you looked closely you could see that the last inch (or so) on both sides (as the stripe melded into the point) was done by someone's very steady hand holding a paint brush. I was amazed to find this out. There was some discussion at our tech session if the NCRS judges were going to start taking a closer look at that and possibly applying a deduct depending.
              • Mel S.
                • August 31, 1992
                • 264
                Thank You very much
                Mel
                • Mel S.
                  • August 31, 1992
                  • 264
                  thank you
                  Mel
                  • Mel S.
                    • August 31, 1992
                    • 264
                    WOW very interesting
                    Mel
                    • Ara G.
                      • January 31, 2008
                      • 1108
                      Great pics Steve
                        • 11698
                        Note that the hood stripe has come under a lot of scrutiny in judging recently.
                        The larger part of the stripe on the raised portion of the hood is also offset to one side.
                        I would recommend contacting John Ballard or similar (well, there is no one similar ) to get specifics.
                        You don't want to have to redo it.
                        • Harry S.
                          • July 31, 2002
                          • 5349
                          John is a good contact. I would also contact the 1967 Team Leader. Nick's contact information is under CONTACTS.
                          • Gary J.
                            • April 1, 1980
                            • 1246
                            BTW... forget about looking in the ‘67 Judging Manual or the Judging Reference manual which has has not been updated since 2010. The information is not there. There are also other characteristics of the stripe, plus do not put any clear over the stripe.
                            • Mel S.
                              • August 31, 1992
                              • 264
                              OK
                              Mel
