65 odometer - NCRS Discussion Boards
65 odometer
  • Ken A.
    • July 31, 1986
    • 929
    Re: 65 odometer
    [QUOTE=Frank Dreano (48332);861088]How so ? If the odometer is locked up and that large gear on the right in my picture above isn't turning then the trip meter should be inoperative
    Your picture is not a mid year speedo but shows the 68 up style.
    • Frank D.
      • December 27, 2007
      • 2703
      Re: 65 odometer
      Originally posted by Carl Schoepe (63533)
      Frank,
      That would be great. I sent you a PM on the Corvette Forum side of things on exactly that with all of my personal information. I would suspect that the bracket would work just fine on a 67 gauge cluster and I would be willing to give it a try. I am good at some things but my metal fabrication skills are pretty weak. Thanks for putting it out there as I had never seen the post or development of the bracket by the other Forum member you speak of.
      I would do most anything to avoid breaking the plastic odometer gear and having to pull the gauge cluster out to replace it. I will be sure to let you know if it works out for the peace of mind to those with 65-67 cars.
      Thank you.
      I threw a few of the brackets on eBay as I kept getting requests for them...
      As you can see in the video in that ad, my clutch pedal is all catywump sideways so I have to pull my cluster anyway in the 63 because the clutch pedal weld broke at the top at the pedal bracket (this'll be the second time)...last time I fixed I had the whole dash out adding Vintage Air A/C. I'm not sure you can move the cross shaft to the left enough to get it out of the pedal bracket without taking a lot of stuff apart - a big PITA.
