C1 (1958) Ride Height Adjustments - NCRS Discussion Boards
  • Jim M.
    • August 7, 2019
    • 14
    Is there any way to adjust the Ride Height or Stance without having to change springs on a 1958?
  • Terry D.
    • May 31, 1987
    • 2697
    Re: C1 (1958) Ride Height Adjustments
    Are you trying to lower it or raise it? What springs do you have now? Original or aftermarket? Four or five leaves? Need a little more info. But yes there are ways. To lower it you could put lowering blocks between the spring and axle, probably require longer ubolts. To raise you could reverse the rear spring shackles or make longer perches. A photo and explanation of what you want to do would help!
    • Jim M.
      • August 7, 2019
      • 14
      The rear just looks a little high so I want to lower the rear of the car. The four leaf springs are not original.
        • May 31, 1974
        • 8408
        de-arch the springs? Or get a pair of originals , which may need arched to achieve the desired lowering of the c-1. mike
        • Terry D.
          • May 31, 1987
          • 2697
          How about a side picture? How much do you want to lower it?
          • Jim M.
            • August 7, 2019
            • 14
            Looking at lowering 1-2"
            • Terry D.
              • May 31, 1987
              • 2697
              Easiest way would be to put one inch lowering blocks between spring and and axle and by the looks or your picture you could probably use the same u-bolts. They make those spacers up to 4 inches but you would need new u-bolts. Is this going to be a judged car? If so Mike's suggestion of finding original springs and have them done at Eaton axle would be the way to go.
              • Jim M.
                • August 7, 2019
                • 14
                Thanks so much, great information.
