tachometer noise 1957 - NCRS Discussion Boards
  • Bruce W.
    • June 30, 1997
    • 358
    Hey Guys,
    Have a frustrating problem. My tach cable makes noise until it is run a while and warms up. Here is what I have done so far. Had the tach rebuilt. replaced the gear drive off of the generator. replaced the cable, Have lubricated the cable with Muscle grease, kable ease lube, lithium. nothing seems to quite it down.
    It seems to me that someone out there has found the answer. Help!! 1957 vette
    Bruce
    • May 31, 1974
    • 8388
    Re: tachometer noise 1957
    is the cable housing in contact with a metal piece? sounds like u have tried all the common fixes. mike
    • Bruce W.
      • June 30, 1997
      • 358
      Hey Mike,
      Have you had this trouble yourself? when I am driving the car I try to move the cable around but it doesn't help. since it goes away once it warms up I am thinking it must be the grease? Do you know of anything else i could try on the cable?
      Bruce
        • May 31, 1974
        • 8388
        I have an old tube of AC Delco speedo cable lubricant. I've had it 40+ years. its got a lead cap and the tube itself is soft like lead. its OLD. the grease is white, pasty consistency and resembles the grease sold today to lubricate brake shoes to backing plates. mike
        • Bruce W.
          • June 30, 1997
          • 358
          Mike, thanks i will check it out
          Bruce
          • Kenneth F.
            • September 30, 1988
            • 282
            Mike, Is the cable the correct length? I found that my noisy speedometer had a cable that was too long.
            Ken
            • Bruce W.
              • June 30, 1997
              • 358
              Hey Ken, thanks. I bought this cable from Corvette central. Do you know what the correct length should be? or where to buy one?Appreciate your help
              Bruce
              • Kenneth F.
                • 282
                Bruce, I had an old speedometer cable I compared to the new one, that was too long. I would think a vendor who repairs guages and sells cables would have specs for the correct overall length, and the length from the bushing to the end of the cable.
                Ken
