HPP Balanced and Surfaced Flywheel 365 HP 327 1965 - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2147
    Bought a '65 project that was worked on in Lincoln, Neb over 12 years ago. On the flywheel (black magic marker) it says "HPP BALANCED AND SURFACED". If you are in Nebraska, or not, please tell me who or what "HPP" means. I wonder if it might be a lead that helps me find a machine shop there.
    Not sure if you can read the writing on the flywheel, but here is a photo.
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • James G.
    • May 31, 1976
    • 1556
    Re: HPP Balanced and Surfaced Flywheel 365 HP 327 1965
    I am thinking Tom, that HPP was a company that ''balanced AND SURFACED THE FLYWHEEL.'' If you pull it off the crank, the part number is on the other side.
    Scoot Freese owns the Harold Sims 66 Race coupe with the proto type 427 L-88 . He also owns a 65 coupe with a ROCK CRUSHER trans. He lives in Omaha if you want to talk to him. He can help with this history.
      • 43287
      Jim------
      If it's original, the casting number will be 3791021.
      • Tom D.
        • 2147
        Thanks Jim and Joe: I found Ron Bockerman in Springfield, NE (Nebraska, near Omaha). His shop is HPR for "High Performance Restorations".
        This car was in his shop in early 2008. The photo below is from 2019, at Thomas Brothers in MI. First red paint since well before 2008, as it was black over orig. red at one time...
        Michigan Chapter
        Tom Dingman
        • James G.
          • May 31, 1976
          • 1556
          Ah yes, 2nd time around. If these cars could only talk. Nice to see it being ''refirbished'' as Bring a Trailer says.
