radio - NCRS Discussion Boards
radio
  • Mel S.
    • August 31, 1992
    • 264
    radio
    How do you remove the radio in my 66 with factory air?
    Mel
  • Don H.
    • December 1, 1981
    • 1494
    Re: radio
    Mel, Here is the "rough draft" as it has been a few years since I did it. Remove both console side panels (easier if you remove the console). Remove the bottom heater diverter box (probably a bad description), it is the metal box directly behind the radio that comes out fairly easy after you remove a few screws. Disconnect the power connector, antenna, & radio knobs. There are nuts behind both knobs and a bolt on the right (passenger) side. I think you can now work it out. If I remember correctly it ends up on its side to come out. Hopefully someone will correct or add to my procedure as needed. Good luck, Don H.
    • Scott S.
      • March 1, 1979
      • 747
      Re: radio
      Mel, I would first take the side panels off. Then check for a rear brace and undo it. Remove the Knobs on the front and push the radio to the front of the car. it is a tight squeeze.
      Scott
      • Jimmy G.
        • November 1, 1979
        • 977
        Re: radio
        Removing the console helps also
        • Mel S.
          • August 31, 1992
          • 264
          Re: radio
          Thanks - i did remove the console, side panels, knobs, nuts bezels power connections, antenna and bole on bottom on the on the passenger side. Just could not get the radio out. i will remove the "heater" outlet.
          Mel
