1966 stamp pad opinions please - NCRS Discussion Boards
  • J W.
    • January 1, 2004
    • 62
    On this 1966 stamp pad, the broach marks look NTFP, but what do others think about the characters?
    • 6948
    Re: 1966 stamp pad opinions please
    Mike, I think the characters look fine, the broaching i connot tell, but appears like the original the grainy lines appear at the top. always nice to have other opinions. how do the casting dates work the stamp?
    • J W.
      • January 1, 2004
      • 62
      Thx Edward. I do not have a photo of the casting date yet to know. Here is another photo that is a little clearer.
      • Patrick B.
        • August 31, 1985
        • 2003
        The Tonawanda characters look ok, but the 3 in the vin looks too wide. The 1s in the vin also look the pieces of type once had horizontal lines at the base that were ground off incompletely with a dremmel tool.
        • Michael H.
          • December 1, 1987
          • 730
          The VIN numbers look suspect I agree with Patrick the 1's look very strange.
          Mike
          • Jim S.
            • March 13, 2013
            • 360
            FWIW, not an expert, the factory fonts I've seen do not match the 3 or the 2 or the 0, or the bottom of the 1. In fact the 6 is a little strange.
            • Harry S.
              • July 31, 2002
              • 5330
              I think of the top of the one having a slope like "Bob Hope's" nose. Just an easy way for me to make a decision.
              • J W.
                • January 1, 2004
                • 62
                • Pancho T.
                  • July 31, 1993
                  • 238
                  I magine that the stamp in question happens to be 425hp car with a M22
                  • Mike M.
                    • May 31, 1974
                    • 8400
                    I wouldn't add that car to our collection if I were still accumulating a collection. mike
                    • Keith W.
                      • June 30, 1998
                      • 375
                      Mike - if you go on the C 2 Registry
                      https://www.c2registry.org/index.php?job=ShowStampPad
                      Look under data base engine stamp 66 - there are a number of pictures of engine pads which you can compare you're stamp to - the two obvious ones that jump out for me are the 6 and the 1 -
                      • Jack M.
                        • March 1, 1991
                        • 1177
                        I'm no expert... just making some observations. I do have one photo of a 1966 T1214 stamp for comparison.
                        Unless there was some issue that day, I would expect those stamps to appear similar.
                        Although the photo angle is slightly different, I've tried to correct the proportions.
                        What are your thoughts... especially on the number '4'?
                        • Larry E.
                          • 1692
                          FWIW> Here is a pad I have in my records which is also a IK pad.AFAIK>Unvarified> Larry
                          Larry
                          LT1 in a 1LE -- One of 134
                          • Rich G.
                            • August 31, 2002
                            • 1403
                            • Jack M.
                              • March 1, 1991
                              • 1177
                              I agree that various style 4's appear in the gang holder... but in most cases, on the exact same day, shouldn't the stamp appear the same?
                              In general, wasn't the stamp date set at the start of the shift, and used throughout the day?
