Tail Light Lens Removal - NCRS Discussion Boards
  • Rob A.
    • February 8, 2011
    • 135
    I have an original unrestored 1967 Corvette and I am going through the operations check list for flight judging. I have one tail lamp that is not functioning and I am unsure how to safely remove the lens to replace the bulb. I have taken the two screws out but the lens won't budge. I don't want to press or pull too hard to remove it. Any suggestions? Thanks
  • Peter H.
    • April 1, 1980
    • 231
    Re: Tail Light Lens Removal
    Rob I have had good Luck gripping the lens with my thumb and the next two fingers and wiggling the lens.Be careful and hang onto the lens.don,t ask me why , I just know...Peter..
    • Keith B.
      • September 15, 2014
      • 1604
      if you get some of those small pick tools with a 90* end you can get behind the lens and pry it off
      • John F.
        • March 23, 2008
        • 2421
        A small screw driver in the "wick" hole should pop it. The little wick may fall out with the lens.
        • Frank D.
          • December 27, 2007
          • 2703
          Absolutely - and make sure they all have the "wicks" since the car is heading for judging...
          The OP may find the bulb contact is not good in which case there are a couple of fixes...if the spring action of the socket is binding some penetrant in the housing while working the contact base back and forth with a Popsicle stick works and if its a repro bulb adding some solder to the two connections at the base will often help..
