1970 ZR1 LOOKING for rare part - NCRS Discussion Boards
  • Gary B.
    • July 31, 1979
    • 926
    Re: 1970 ZR1 LOOKING for rare part
    Not the best picture, but this is the style I am use to seeing on them.
    Gary B
    • Ronald R.
      • May 31, 1989
      • 670
      Is this a 69 or 70? thanks
      • Kent S.
        • February 1, 1993
        • 203
        #18
        Here's an ad for the guy I've used (not on Corvettes) but it works perfectly and he's a great guy to deal with.
        • Ronald R.
          • May 31, 1989
          • 670
          #19
          This is what I had on my L88, I think joe is right my speedometer was correct with no adapter until it broke!! thanks Ronnie
          • Gary B.
            • July 31, 1979
            • 926
            #20
            Picture is from a late 72. But the 70, 71 and 72's I have seen look like this.
            Gary B
            • Gary B.
              • July 31, 1979
              • 926
              #21
              What the stamping on the adapter said.
              Gary B
                • 43221
                #22
                Gary B
                Gary------
                The GM #6477965 speedometer adapter pictured was used for 1970 Corvettes with wide ratio M-20 4 speed and 3.55:1, 3.70:1, and 4.11:1 rear gear ratios. Of course, no 1970 ZR-1 was ever originally equipped with such a transmission.
                The 6477965 was also used for 1971-72 Corvettes with 4.11:1 rear gear ratio.
                Speedometer adapter GM #6477966 was used for 1970 Corvettes with close ratio M-21 4 speed and 3.08:1 and 3.36:1 rear gear ratio.
                • Terry L.
                  • August 13, 2007
                  • 99
                  #23
                  My 70 LT1 has a 4:11 with this adapter, I also think I have a M21. I
                  Gary B
                    • 43221
                    #24
                    Terry------
                    I do not understand why you would have an adapter with a 1970 LT-1 unless it's actually a wide ratio with 3.36:1 or 3.55:1.
                    Do you have the actual rear end code, transmission code, adapter part number, and casting number of the transmission extension housing?
                    • Gary B.
                      • July 31, 1979
                      • 926
                      #25
                      This is from a 72, Automatic with a 3:36 Differential.
                      Gary B
                      • Terry L.
                        • August 13, 2007
                        • 99
                        #26
                        • Wayne M.
                          • March 1, 1980
                          • 6414
                          #27
                          Here's the chart from the 1970 P&A30B parts catalog (Corvette only). Also has chart for 1968 and 1969. Also two Stewart-Warner units. Sorry about the orientation of the chart -- the original is OK.
                            • 43221
                            #28
                            Gary B
                            Gary------
                            The 1972 with THM-400 and 3.36:1 application did use a speedometer adapter and the part number should be GM #6477964 if it's original.
                            • Dick W.
                              • 10483
                              #29
                              Gary------
                              Joe, never seen one with a GM #. Always a Stewart Warner and the ratio as shown in another post in this thread. First # is the input and the second is the output. For instance the one shown had a 1 input and .834 output.
                              Stewart Warner does not manufacture these any more, S S White is the source.
                              Dick Whittington
                                • 43221
                                #30
                                Dick------
                                The one shown above in Terry's #23 post has both the GM part number and ratio.
                                Both the AC Division of GM and Stewart-Warner manufactured these speedometer adapters. In fact, the one in Terry's post was manufactured by AC. I think (but I'm not sure) that units manufactured by AC had a seven digit part number beginning with "64" as this was a series of part numbers assigned to the AC Division. Many original speedometer adapters had Chevrolet part numbers (seven digit part numbers beginning with "38" or "39"). I suppose these may have been either of AC or Stewart-Warner manufacture. It could have been that units manufactured by AC had dual part numbers-----both AC Division and Chevrolet.
