1970 ZR1 LOOKING for rare part - NCRS Discussion Boards
  • Ronald R.
    • May 31, 1989
    • 671
    1970 ZR1 Corvette speedometer gear reduction unit with 411 rear end. Anyone seen one of these? I had a L88 that had one, my ZR1 does not have one, thanks RDR
  • Ronald R.
    • May 31, 1989
    • 671
    Re: 1970 ZR1 LOOKING for rare part
    If anyone has a picture of the correct unit please post! thanks RDR
      • 15615
      Ronnie
      Not hard to find a picture. Google is your friend:
      See the Stewart Warner item. Also the one for Camaro.
      BTW: The same gear reduction unit was used on any Corvette with 4:11 gears. I would think a similar unit was used in other GM vehicles with 4:11 gears. I know the same looking unit (with different internal gears) was used for 4:56 rear end. If there are any speedometer correction shops left in the world they likely have a drawer full of them and the internal gears to adjust the speedometer for accuracy.
      • Mike M.
        • May 31, 1974
        • 8400
        terry: u imply the gear reduction units were commonly used on corvettes. i've never seen one on a c-1 or c-2 although i acquired one in the Don Blatchley stash i received in the late 70's(u will recall ole doc bletchley bought grady davis's year old corvettes and ran them in scca. ) don had a 62, a 63, a 66 and lastly a 69. perhaps the gear unit was born with the 69. enlighten me regarding the usage of these units. thanks, mike
        • Ronald R.
          • May 31, 1989
          • 671
          Seems to be several Stewart and Warner styles, right angle and strait many of each. I have a poor picture of a 69 Camero 396/425/456 that is right angle thanks RDR
          • Ronald R.
            • May 31, 1989
            • 671
            The JM shows them only on the L88 and ZR1 with 411 or 456 axle ratios??? Thanks RDR
            • Dick W.
              • 10483
              Go to a HD truck salvage yard that has older trucks. They were used on many makes. If you find one and the ratio is wrong, I have a complete selection of gears and shafts. Just need to know the ratio you need
              Dick Whittington
              • Ronald R.
                • May 31, 1989
                • 671
                Is this the style? thanks RDR
                • Ronald R.
                  • May 31, 1989
                  • 671
                  or possible one of these? Or does anyone really lnow? thanks RDR
                    • 15615
                    Mike
                    You know I know nothing of C1s or C2s. I don't even think of those when I answer here, but I guess I should limit my comments. Time to pack anyway; and stop this foolishness.
                    We see them on the chrome bumper C3s with those deep axle ratios I mentioned. It wouldn't surprise me to see them on other Muncie so equipped Corvettes, but I plead ignorance.
                      • 15615
                      You got it.
                      • Ronald R.
                        • May 31, 1989
                        • 671
                        I have found a guy thar owned a speedo shop for 40 plus years and he will have the correct one just need to know what correct is? thanks for any guidance RDR
                          • 15615
                          The one on the left in the first picture.
                          • Ronald R.
                            • May 31, 1989
                            • 671
                            This guys has several and the gears to make it work, thanks for the help!!! Ronnie
                              • 43246
                              Ronald------
                              According to GM the correct speedometer adapter for your application is NO ADAPTER. An adapter was not used for 1970 Corvettes with 4.11:1 axle ratio. Your application used a speedometer DRIVE gear of GM #3924097 and DRIVEN gear GM #3860348. The latter is a 25 tooth gear and orange color-coded. The 3924097 DRIVE gear was replaced by GM #6261795 in March, 1975. The latter was discontinued without supercession in March, 1999. The 3860348 DRIVEN gear was discontinued without supercession several years ago. I believe that replacements for both gears are available in the aftermarket.
                              If you had a 1971-72 ZR-1 with 4.11:1 rear gear ratio then different speedometer gears would have been used in conjunction with a speedometer adapter.
                              1967-69 Corvettes with 4.56:1 or 4.88:1 rear gear ratio did use a speedometer adapter. 1967-69 Corvettes with 4.11:1 rear gear ratios did not use an adapter.
