Can an N.O.S. Ignition coil go bad - NCRS Discussion Boards
  • Joseph C.
    • June 10, 2012
    • 17
    I recently purchased an N.O.S.ignition coil for our 1965 Corvette. Can a coil go bad just from age sitting in a unopened box. I now realize I should have asked this question before buying. Stupid me. Thanks, Duke
  • Harry S.
    • July 31, 2002
    • 5345
    Re: Can an N.O.S. Ignition coil go bad
    I guess new defective is possible. What is happening to make you think it's bad?
    • Joseph C.
      • June 10, 2012
      • 17
      • Larry M.
        • January 1, 1992
        • 2702
        It should be fine. You can test it before installation. Chevrolet Service has the specs. It requires an Ohm Meter or Multimeter.
        Or just install it and start the car.
        Larry
        • Harry S.
          • July 31, 2002
          • 5345
          To test, in case you have one of these.
          The secondary winding of your ignition coil 087 OEM 087 reproduction 202 OEM
          Ohms Ohms Ohms
          Primary Winding 1.8 2.4 2.2
          Secondary Winding 7.9K 11.71K 14.46K
          • Joseph C.
            • June 10, 2012
            • 17
            Thanks to everyone for your time and fine answers. Your knowledge is truly appreciated, Duke
            • Danny P.
              • Today
              Joseph, i been through at least 5 repro. coils before i got a good one , it's a hit and miss even if you check the coil's primary and secondary winding are in proper Ohms specs. there made in China and box in U.S Delco box's it start the car after running for a couple hours or less the car start acting up and coil start getting hot and breaks down.
              • Joseph C.
                • June 10, 2012
                • 17
                Hi DANNY,
                The one in the car is a repro GM authorized Chinese piece. So far it has worked okay. The one I ordered is a genuine N.O.S. coil in a sealed GM box. Your thoughts on the Chinese is why I ordered an NOS piece. Thanks for sharing your thoughts, Duke
                • Jim D.
                  • 2885
                  I and several others I know have had the same issues as Danny did with the Chinese made reproduction coils.
                  • Joseph C.
                    • June 10, 2012
                    • 17
                    • Harry S.
                      • July 31, 2002
                      • 5345
                      It sounds to me that he has a NOS Delco in a sealed box with a string.
                      • Ed D.
                        • December 1, 1990
                        • 329
                        Hey Duke,
                        I think that the primary reason that coils fail, is due to vibration and heat cycles. That said I know of many bad coils that fail out of the box, which I believe is manufacturing defect.
                        Ed
                        Ed DiNapoli
                        CNJ Chapter Past Chairman/Co Founder
                        1972 Targa Blue Coupe, Original Owner,
                        Duntov Award, Sam Foltz Award,
                        Founders Award, NCRS Gallery VIII
                        2011 Corvette Convertible
                        NCRS Presidents Award 2014
                        • Edward B.
                          • January 1, 1988
                          • 537
                          Failure rate for NOS coil will be a lot less than the stuff being made today. It's a real test of one's diagnostic skills to replace what you believe to be a bad electrical part with a new one from the box and have the problem persist. Replace it with another new part, experience the same problem and you're really scratching your head. Unfortunately, today it's not uncommon to go through several new coils, relays, etc., before finding one that works. QC on the offshore electrical replacement components is awful.
