horn relay - NCRS Discussion Boards
horn relay
  • Howard H.
    • January 10, 2007
    • 139
    horn relay
    On a 70, should there be constant 12 volts from the 10 gauge red wire that runs from the battery connection on the solenoid to the horn relay? I am getting no voltage to the relay with key on or off. Doc Rebuild's wiring diagram tells me that there should be. What am I missing?
  • Mark E.
    • April 1, 1993
    • 4606
    Re: horn relay
    Yes, there should be 12 volts at the horn relay bus at all times. If there isn't, check for voltage at the starter solenoid. Common reasons for an open between the solenoid and relay include a blown fusible link or loose/dirty connections. The link is near the solenoid.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Howard H.
      • January 10, 2007
      • 139
      Re: horn relay
      Thanks Mark, I thought so. Looks like we have about the same car except mine has Black Deluxe interior and no alarm system.
