Packard 440 ignition wire on 66 L72 - NCRS Discussion Boards
  • Robert M.
    • January 1, 1992
    • 78
    Can I install packard 440 solid core wire on my 66 L72 with stock TI ignition?
    Thanks Bob
  • Bruce W.
    • June 30, 1997
    • 360
    Re: Packard 440 ignition wire on 66 L72
    Robert, yes you can and you will be happy you did. you get a point deduction if you are having it judged. doesn't have the correct marking TVRS GM radio. You can have a rubber stamp made and put the correct markings on it. You will get better performance
    Bruce
    • Harry S.
      • July 31, 2002
      • 5330
      What Bruce said... Depending if you run your radio shielding or not you may get more static on your radio.
      • Robert M.
        • January 1, 1992
        • 78
        • Ray K.
          • July 31, 1985
          • 375
          Bob,
          Many years ago I made up a set of the 440 wires for my 1965 L 78. Using the braided shielding from the TVRS set that I removed from the car, I inserted the 440 wires into the shielding and installed on the car. Could not detect any radio noise when running.
          Ray
          • William F.
            • June 9, 2009
            • 1364
            Spiral wound ignition wires newer way to go. Some electronic trigger ignition systems such as Pertronix and maybe MSD say do not use solid core wires.
