Exhaust Manifold vs Headers - NCRS Discussion Boards
  • Mike L.
    • September 28, 2016
    • 50
    I have a 64 numbers matching 327/365hp coupe. One exhaust manifold just cracked and my
    question is "do I now put Headers on or try to keep original and put back on manifolds?
    Mike
  • Donald O.
    • May 31, 1990
    • 1593
    Re: Exhaust Manifold vs Headers
    Mike,
    There is a lot less to change if you just get a stock replacement ram's horn exhaust manifold.
    Have asked around locally to you if there is a cast iron welder that would do it?
    IF you switch, you'll also need a new header collector pipe to connect to the rear exhaust pipe or bubba something to a side exhaust. Plus you may have to modify how the alternator is mounted, and the power steering (if so equipped).
    BUT.... IF YOU RACE, you should have switched to headers along time ago.
    Don
    • Mike L.
      • 50
      Thanx Don,
      I was told that you can't weld cast iron manifolds!
      • Richard G.
        • July 31, 1984
        • 1718
        You can weld them.
        Brazing may be better.
        Both are not the best fixes and easily identified.
        What not just go on Ebay and purchase the correct manifold for your car?
        The Non-FI manifolds are not outrageous.
        GM made service replacement for years after our cars were manufactured.
        They will fit fine and cost even less.
        And of course, the China made copies that all the Corvette Parts dealers stock.
        Best of luck.
        • Ed S.
          • August 6, 2014
          • 1377
          It's a 55 year old car with engine technology that is 60 + years old. How much HP are you going to gain with headers - is it worth it? Course of least resistance is to find an original manifold. Probably a lot less expensive too.
          Ed
            • 43259
            Mike
            Mike------
            I would not even consider putting aftermarket headers on any street car. Just buy another manifold. I prefer new ones. Excellent reproductions are available.
            • Mark E.
              • April 1, 1993
              • 4603
              Headers in a car with fiberglass body is a recipe for even more heat in the interior.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
                • 11678
                Mike------
                There are some reasonably good reproductions, and some really bad ones.
                Paragon and others sell the reasonably good ones. Note that they are detectable, so if you want to be as original as possible you will look for a good used one.
                Be careful on eBay and through mass-market sellers. A friend had a foreign junk one break the first day he ran the motor.
                • Jack J.
                  • July 31, 2000
                  • 640
                  Mike, which manifold cracked?
                    • 43259
                    Patrick------
                    The inferior manifolds of which you speak I do not consider as reproductions. I consider those to be just replacements. I'd never use one unless there was absolutely no alternative.
                      • 43259
                      Mark-------
                      That's one of the biggest problems with headers, even on a steel bodied car but more pronounced on a Corvette. I once talked with a guy that had installed them on a 1971 LS-6. He said the heat problem in the passenger compartment was so bad he was going to remove them and go back to cast iron manifolds.
                      • Mike L.
                        • 50
                        Passenger side below the original air conditioning. LOL.
                        • Mike L.
                          • 50
                          Thanx Ed. I wanted to keep the car original as possible especially because the exhaust is original too but some motorhead
                          suggested that I put headers on.
                          • Mike L.
                            • 50
                            Thanx Richard
                            • Mike L.
                              • 50
                              Thanx Joe, that's what I was thinking but this is my first vette!
