1968 Headlights - NCRS Discussion Boards
1968 Headlights
  • Jeff P.
    • 799
    1968 Headlights
    Low beams come on fine. On high beams the right low beam goes out. I purchased another low,high beam bulb and the same thing happened. Any help here ?
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • David M.
    • September 30, 2004
    • 533
    Re: 1968 Headlights
    Step 1. Check the forward harness and headlight grounds and all 4 connectors on the bulbs. Look at the spade connectors in the plastic housings. Should be clean and tight for all the above items. Get the diagram if you dont have one.
    Step 2. Check for voltage at each connector when the bulb should be on.
    • Jeff P.
      • 799
      Re: 1968 Headlights
      Thank you David. I do have a schematic for the headlamps. The wire of concern is tan.
