1973 Special order Black paint L82 4 speed coupe -
Re: 1973 Special order Black paint L82 4 speed coupe -
I am the original owner of a 73 coupe # 22xxx . Years ago my gas tank began to leak in the passenger side lower rear corner. I purchased a new one through GM , removed the original that had NO tank sticker and never did. I do have the build/broadcast sheet but never a tank sticker.So in my opinion, I question whether 73's had tank stickers. My car has 27,000 miles with lots and lots of survivor/original parts. I participated with info on my car to the 73-74 revision, so Tom Russo and Jim Patitucci have pics/knowledge on my car. Congratulations on your new to you car. Hope this helps . Curt- Top
Here are some weatherstripping and door jamb details.
James A Groome
1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453- Top
GM would not sell a car without the Blue certification sticker on the door. It would be a violation of Federal law that GM would certainly avoid.- Top
I HIGHLY doubt that the factory would ship a car without weatherstrip installed. The only POSSIBILITY I could see would be if they shipped a car in primer to be painted later.
As far as what tires were originally on the car, you MIGHT be able to tell if the original spare tire is still in the tub. Radial tires were not supposed to have been rotated according to the old rotation pattern which sometimes included the spare tire. So, there's a better chance the spare could still be original.
Does the tire pressure sticker on the door have a part number on it?
I don't know if there was an ordering restriction that prevented a 1973 with Z-07 from also being equipped with C-60. There may have been but I don't know that there was. It's very easy to discern if the car was equipped with Z-07. The easiest way is just to observe the rear spring. If it's 9 leaves, it's standard suspension; if it's 7 leaves, it's Z-07In Appreciation of John Hinckley- Top
Here are some more photos...
the tire pressure label part number... -
Black over spray in the seat belt recess area, drivers side...
Black overspray in the pass side foot well above the kick panel...
Runs in the paint and glue -
James A Groome
RH Stamp on ALT
EGR with line and clamp.
WIPER MOTOR DATE
WK ink stamp on Trans
James A Groome
Block Date - 014 block
T1 block casting
Drivers side of engine - original plug wires dated 2 Q 72 and 3 Q 72
Freezeplug with no markings and steel shim head gasket.
James A Groome
Heater hoses
Heater hose - dated
Emissions hose
James A Groome
Front headlamp hoses etc
Headlamp actuator.
throttle return spring
M1 radiator tag
James A Groome
Spring tags
Front crossmember grease pencil mark
Emissions decal - HP
James A Groome
MID-PIPE CLAMPS - 2-1/2" original
D shaped CONTROL crimp pipes
Rear exhaust clamps - HD
REAR VALENCE DATE
James A Groome
By "014" block are you referring to a GM #3970014 block? If so, that's a Tonawanda-cast block and these were, as far as I know, not used in Corvettes for 1969 and later. What does the stamp pad on this engine look like?In Appreciation of John Hinckley- Top
Attached Files- Top
